Settings or even pi-hole updates not getting saved
I'm using pi-hole on raspbian on a pi3, I'm on version 4.0, and here are my issues:
When I try to update the static ip in dhcp, they don't get saved, even if the web interface says "saved succcessfully".
I tried to upgrade to latest version of pi hole using pihole -up, the script goes well, but after a restart, the pihole version goes back to 4.0.
I even uninstalled and re-installed pihole with same results (going from 4.2.2 to 4.0 after a reboot)! (i didn't reboot between the uninstallation and reinstallation). And after the reinstallation, my dhcp static ips were still there!
Being able to update pi hole to latest version, and my dhcp settings via the webinterface.
for information, here are the dnsmasq.d files that I suppose should get updated:
pi@raspberrypi:/etc/dnsmasq.d $ ls -ltr
total 12
-rw-r--r-- 1 root root 483 Sep 15 2018 02-pihole-dhcp.conf
-rw-r--r-- 1 root root 1122 Oct 10 04:12 04-pihole-static-dhcp.conf
-rw-r--r-- 1 root root 1589 Dec 9 22:16 01-pihole.conf
https://tricorder.pi-hole.net/40cg1fsw2a
Sounds like a bad SD card that has gone in to read-only mode. Try creating a file in your home directory and see if that file still exists after a restart of the Pi.
Indeed, a newly created file disappear after reboot.
Thanks for your help. I will back the sd to another card.
