I've followed the guides to install Pi-hole and ufw on a RPi 3B+ with Raspbian Stretch Lite. My RPi has ip 192.168.86.254.
I'm using Google Wifi as router. In Google Wifi settings I have setup custom DNS 192.168.86.254. I have also made this ip static.
Besides installing Pi-hole I have also installed ufw with these settings:
Default: deny (incoming), allow (outgoing), disabled (routed)
To Action From
Anywhere ALLOW 192.168.86.0/24
64321/tcp ALLOW Anywhere
64321/tcp (v6) ALLOW Anywhere (v6)
Port 64321 is used for torrenting.
This is all working as expected. I've been using Pi-hole successfully for several weeks.
Now, I also want to add a VPN. I have a Nordvpn account and have followed this guide https://www.addictivetips.com/vpn/raspberry-pi-vpn-setup/. According to the guide I should install openvpn and download NordVPN .ovpn configuration files. This I have done. I have successfully connected using this command:
sudo openvpn de75.nordvpn.com.udp1194.ovpn
In order to get all other devices on my home network to use Nordvpn using this connection I have edited de75.nordvpn.com.udp1194.ovpn adding the line push "dhcp-option DNS 192.168.86.254".
I have also changed Upstream DNS Servers Custom #1and #2 to 103.86.96.100#53 and 103.86.99.100#53 (source for DNS was https://support.nordvpn.com/Other/1047409702/What-are-your-DNS-server-addresses.htm).
I then also changed Interface listening behaviour to Listen on all interfaces, permit all origins.
DHCP Settings is not enabled.
I have restarted RPi.
However, when I go to https://nordvpn.com from my devices I get the message at the top that my connection is not secure.
What am I missing in this scenario? Why will my devices not use VPN?
