Setting up Pi Hole with SKY Q Hub Router?
Hi Guys,
Have the PI Hole Setup but I was wondering if anyone has turned off DCHP on the sky q hub router and allowed the pi to take over for a true network wide solution?
At the moment I've had to manually changed the settings on my pc
Any help would be great!
Apologies, I seem to have gotten mixed up
I can disable dchp on my router - will that be enough to make the pihole the default gateway?
If Pi-Hole is the DHCP server, it becomes the assigned DNS server as well.
The router continues to be the gateway, as this is where the actual traffic flows. The Pi-Hole provides the DNS resolution only.
