Setting local-ttl in pihole v6
I used to be able to set the local-ttl for local records to something like 120-300 seconds to prevent my array of local services filling the query log with tens of thousands of requests daily due to a default 0 ttl.
I can no longer find this setting in pihole v6. Previously it had to be set via adding 'local-ttl = ' to a config file in etc/dnsmasq.d/
This file no longer exists/is read. local-ttl also does not exist in pihole.toml and is automatically removed if manually added.
I don't know where I should set this now.
Pihole core v6.0.3, docker tag 2025.02.3
For a single line, you can use misc.dnsmasq_lines under All settings » Miscellaneous.
If instead you want to keep a bunch of configuration lines in your own custom file under /etc/dnsmasq.d/, you could also enable misc.etc_dnsmasq_d.
All settings is available in Expert mode only.
Excellent, thanks!
Adding 'local-ttl=300' to 'misc.dnsmasq_lines' worked perfectly.
