I’m trying to configure PiHole inside a docker container to assure high availability.
I have two hosts that runs docker and there is a virtual ip configured between that hosts. The configuration is Active-Passive, when the first host goes down the VIP will be automatically assigned to the second host and the backup PiHole instance start to answers to the A queries. I need that PiHole uses the VIP IP address to answer the A query instead the physical IP address assigned to the network interface. How can I achieve that behaviour? I tried to use the LOCAL_IPV4=
parameter but the A replies still uses the physical IP address.
Thank you to every one.
