Excuse me, I'm new here on the forum!
As for VMWare, check out memory reclamation, or just overcommit.
Running the lighttpd web server is optional. You can almost completely control and monitor Pi-Hole from the command line.
How do I disable it? I was thinking about collecting the data via API for GRAFANA.
it is an option on install
or using
sudo systemctl disable lighttpd.service
sudo systemctl stop lighttpd.service
Simple is to just sudo systemctl disable lighttpd.conf
and stop the lighttpd
server from starting. But you'll need to edit /etc/pihole/setupVars.conf
to also show
INSTALL_WEB_SERVER=false
LIGHTTPD_ENABLED=false
Heh, yeah. But I think in this case the free memory isn't being given back to the hypervisor. The VM is locking it for it's own use. That's why I mentioned checking for reclamation options. Or just overcommit memory and let each VM battledome for the resources.
O dear, malloc not playing along
Thank you very much for your help!
