Since updating to v6, I've been seeing the following in my Pi-hole diagnosis page: Connection error (9.9.9.9#53): TCP connection failed while receiving payload length from upstream (Resource temporarily unavailable)
In DNS Settings, I noticed I had set this at some time in the past. I unchecked those and saved; however, all resolution failed. I use a UniFi Dream Machine SE as my security gateway and do not have any other DNS IPs except my pi-hole IP. I'm not concerned with this error just curious what I'm doing wrong or need to change in my settings page to get it to go away.
Thank you for the response. I saw it in the template and was hopeful this was a quick fix and did not need one. Apologies on my laziness! Will remember for next time.
Please upload a new debug log and post just the token URL that is generated after the log is uploaded by running the following command from the Pi-hole host terminal:
`[?] Would you like to upload the log? [y/N] y
* Error message: curl: (22) The requested URL returned error: 400
[β] There was an error uploading your debug log.
Please try again or contact the Pi-hole team for assistance.`
