I have two Pi-hole dockers running on two different NAS units. When I manually shutdown the first or primary Pi-hole, my devices did not automatically pick up the second as desired.
I've seen two solutions offered, one with Keepalived and on with some configuration in Pi-hole.
Is there a viable keepalived solution that is easy to implement and preferably where a docker that can be installed on both NAS units is available?
Or is the configuration option detailed some place clearly?
From within UnRaid, Docker, Binhex-Official-Pihole, right-click, >_Console, I type in what you suggested /# docker exec -it Binhex-Official-Pihole pihole -d, I end up with bash: docker: command not found.
Which means I am doing it wrong or in the wrong place.
Ok, I am chipping away at this learning curve. I was able to ssh into my Qnap, ran the command you presented tome and have taken it from my clipboard and posted it in Notepadd++. It is very long. Is there just a section you need. I searched within the file, token URL but could not find it.
I discovered in the process of doing this that if I enter the two Pi-hole static IP's in the devices, rather than the router, shutting one down, it seems to rollover to the second one as I hoped it would do on my router. So I am going to go with this option as it would be the simplest than trying to run another app I am not familiar with at the time.
