is it possible to manage a secondary dns from gui?
Please clarify what you want to do? "Secondary DNS"?
There are 2 pi-holes in my network.
the first pi-hole is the dhcp server.
To configure two DNS I manually edited the "02-pihole-dhcp.conf" file.
If pi-hole is updated I lose the change.
is it possible to set the secondary dns from gui without losing the changes?
Please clarify what you want to do.
Do you want to distribute both your Pi-hole's IPs as DNS server via DHCP?
