I got one of those PoE Splitters and would like to plug it in. Am I correct that I just have to go to Settings/System/ Power Off System , and then when I plug it back in will just come back? I am running Pi-hole on a Raspberry Pi 4 right now and it is working perfectly
You are correct. Power it off using a controlled shutdown, and Pi-hole will start normally on Pi restart.
