I have previously been running my Pi-hole in a docker container with port forwarding. I connected to the Pi-hole using the host machine's tailscale IP. This all worked fine, except all requests were logged twice (image below)
So I decided to change the docker setup so the container would be its own Tailscale node and pihole listens on the tailscale network. The docker compose is below.
version: "3.7"
services:
tailscale:
image: tailscale/tailscale:latest
hostname: pi-hole
environment:
- TS_AUTHKEY=REDACTED?ephemeral=false&preauthorized=true
- TS_EXTRA_ARGS=--accept-dns=false --advertise-tags=tag:dns --ssh
- TS_STATE_DIR=/var/lib/tailscale
volumes:
- './tailscale-data:/var/lib/tailscale'
- /dev/net/tun:/dev/net/tun
cap_add:
- NET_ADMIN
- SYS_MODULE
restart: unless-stopped
pihole:
container_name: pihole
image: pihole/pihole:latest
environment:
TZ: 'America/New_York'
WEBPASSWORD: 'REDACTED'
volumes:
- './etc-pihole:/etc/pihole'
depends_on:
- tailscale
network_mode: service:tailscale
volumes:
tailscale-data:
driver: local
The Pi-hole works like this, but now all requests come from localhost in the logs (below)
Has anyone figured out a setup like this?
