This is not really a question regarding Pi-hole, but maybe someone can help me out here.
I got these two warnings in Pi-hole diagnostics this morning:
Disk shortage (/etc/pihole/pihole-FTL.db) ahead: 96% used
/etc/pihole: 29.7GB used, 30.8GB total
Disk shortage (/var/log/pihole/FTL.log) ahead: 96% used
/var/log/pihole: 29.7GB used, 30.8GB total
You can try to search for large files using the find command ( you may need to install it if its not already there ).
sudo find / -type f -size +50M -exec ls -Shl {} +
This will look for a files over 50 megabytes and then post them using the ls command. You can change the +50M to anything you like ie +1G would be 1 gigbyte files etc.
It looks like you're not getting a full picture from the command you used. Try running the interactive du below, this will sort by size and let you explore to see where the space is being used. You can install ncdu if it's not present.
761.0 GB [##############################] /mnt
2.8 GB [ ] /var
2.0 GB [ ] /usr
602.9 MB [ ] /etc
219.4 MB [ ] /boot
26.4 MB [ ] /home
7.5 MB [ ] /dev
4.2 MB [ ] /run
286.7 KB [ ] /opt
57.3 KB [ ] /tmp
41.0 KB [ ] /root
e 16.4 KB [ ] /lost+found
e 4.1 KB [ ] /srv
e 4.1 KB [ ] /media
0.0 B [ ] /sys
. 0.0 B [ ] /proc
@ 0.0 B [ ] initrd.img.old
@ 0.0 B [ ] vmlinuz.old
@ 0.0 B [ ] vmlinuz
@ 0.0 B [ ] sbin
@ 0.0 B [ ] lib
@ 0.0 B [ ] bin
But I noticed some errors when using du:
du: cannot access '/proc/83611/task/83611/fd/4': No such file or directory
du: cannot access '/proc/83611/task/83611/fdinfo/4': No such file or directory
du: cannot access '/proc/83611/fd/3': No such file or directory
du: cannot access '/proc/83611/fdinfo/3': No such file or directory
Please elaborate on the involvement of Time Machine with this Pi. You are backing the Pi up to a Time Machine drive? Of, you are using the Pi as a Time Machine server?
I mounted a 5 TB External hard drive to /mnt/timemachine and back up my MacBook. I have this setup running for a couple of months now. And never had this warning before.
Yesterday, my old hard drive died, I removed it and added a new one. Nothing besides that changed. And now I'm just doing the initial backup (~1.2 TB).
I mounted the new drive to the same path as I did with the old one. The only change, of course, was the UUID in /etc/fstab.
Time Machine can do some strange things with files (sparse bundles, snapshots, etc.).
Given that your problem started when you replaced a drive, my inclination would be that the two events are related.
Let Time Machine do its thing for a few days and see if the issue resolves.
For what it's worth, I also run a MacBook Pro, and I just hook the backup drives directly to a USB hub connected to the Mac. The Mac software does the work without needing a separate Time Machine server. I have two drives connected most of the time, and Time Machine rotates through them each time a backup is done.
I know you figured it out, but I would suggest that any mount point directories be set to read-only. Once a device partition is mounted to the mount point, the permissions of the mounted file system take over.
I learned about this after having a drive fill up, and I could not figure out why. After some time digging around, I discovered that at one point I had failed to mount an external drive the path /media/temp that I had created. Copied some data to /media/temp, thinking it was going to my external drive. Once I figured it out, read that mount points could be marked read-only, and that they would adopt the mounted devices permissions. Lesson learned for me.
