Rsyslog stops reading logs after log rotate
The issue I am facing:
Running pihole i want the logs in a SIEM system ( Graylog ) and i found that Rsyslog had a relatively easy config file to setup to read from Pihole.
My issue is that once the pihole around midnight log rotates Rsyslog loses the file and needs a full apt-get remove and apt-get install before it starts reading again.. restarting the service is not enough.
Details about my system:
the Pihole is setup pretty bare bones it reads some lists from github to update gravity and thats about it
running on ubuntu 22.04
my rsyslog config here
 # /etc/rsyslog.conf configuration file for rsyslog
# For more information install rsyslog-doc and see
# /usr/share/doc/rsyslog-doc/html/configuration/index.html
# Default logging rules can be found in /etc/rsyslog.d/50-default.conf
#### MODULES ####
module(load="imuxsock") # provides support for local system logging
#module(load="immark") # provides --MARK-- message capability
# provides UDP syslog reception
#module(load="imudp")
#input(type="imudp" port="514")
# provides TCP syslog reception
#module(load="imtcp")
#input(type="imtcp" port="514")
# provides kernel logging support and enable non-kernel klog messages
module(load="imklog" permitnonkernelfacility="on")
#### GLOBAL DIRECTIVES ####
# Use traditional timestamp format.
# To enable high precision timestamps, comment out the following line.
$ActionFileDefaultTemplate RSYSLOG_TraditionalFileFormat
# Filter duplicated messages
$RepeatedMsgReduction on
# Set the default permissions for all log files.
$FileOwner syslog
$FileGroup adm
$FileCreateMode 0640
$DirCreateMode 0755
$Umask 0022
$PrivDropToUser syslog
$PrivDropToGroup adm
# Where to place spool and state files
$WorkDirectory /var/spool/rsyslog
# Include all config files in /etc/rsyslog.d/
$IncludeConfig /etc/rsyslog.d/*.conf
and my 22-graylog.conf here
 # Forward all logs to graylog:
*.* action(type="omfwd" target="XXXXXXXX" protocol="tcp"
action.resumeRetryCount="100"
queue.type="linkedList" queue.size="10000")
# Define extra log sources:
module(load="imfile" PollingInterval="30")
input(type="imfile" File="/var/log/pihole.log"
Tag="pihole"
StateFile="/var/spool/rsyslog/piholestate1"
Severity="notice"
Facility="local1")
input(type="imfile" File="/var/log/pihole-FTL.log"
Tag="piFTL"
StateFile="/var/spool/rsyslog/piFTLstate1"
Severity="notice"
Facility="local1")
have anyone got a clue how i can get this working for longer than 24 hours? :slight_smile:
Not applicable other than installing Rsyslog its bare bones Ubuntu 22.04 server with pihole setup
I'm not familiar with how your doing this but I do not believe that pihole rotates the logs. I believe this would be a logrotate function. Perhaps you need to add a specific config in /etc/logrotate.d?
I also found this old thread. It was never responded to / resolved but might provide some additional insight.
Log are rotated by logrotate, as CallMeCurious said.
