Revert to Lighttpd
I have just done an update (long overdue) and mistakenly moved from lighttpd. Is there an easy way to return to using lighttpd?
Version 6 has it's own webserver, lighttpd is not needed nor used.
If you need lighttpd to run other web services, you can reinstall it, but Pi-hole v6 web interface need the new web server and it won't work with lighttpd.
Is there anyway to set it up with an SSL certificate as I did for previous versions on Lighttpd?
Thanks I have done a linked thread as we are now OT.
