Reverse Proxy using lighttpd impossible with external.conf
I added "mod_proxy" to the "server.modules" option in /etc/lighttpd/lighttpd.conf and the following snippet in
/etc/lighttpd/external.conf:
$HTTP["host"] == "pi" {
# Undo Pi-hole Javascript Redirect
url.rewrite = ("^(?!.)..js$" => ".*.js")
proxy.server = ( "/" =>
                       "host" => "192.168.1.32",
                       "port" => 8080
I have not found a way to place the "mod_proxy" option into the persistent /etc/lighttpd/external.conf file. Lighttpd doesn't allow a second "server.modules" option.
I think this problem is different to the Reverse proxy feature request.
Can it work via:
server.modules += ( "mod_proxy" )
I couldn't believe it's so easy but it finally works.
So glad you helped me out.
Thank you a lot!
