Reverse Proxy stopped working after v6 upgrade
I am running Pi-hole version 5 (hostname: server2.xxxxxxxxx.com, IP: 172.16.100.203) on a robust desktop PC with Ubuntu OS. My network is managed by pfSense as the router, with HAProxy (IP: 172.16.100.1) configured as the reverse proxy. The IP for server2.xxxxxxxxx.com has been added to Pi-hole's local DNS records, enabling secure access via Let's Encrypt certificates. I am able to successfully resolve server2.xxxxxxxxx.com to 172.16.100.1 and also utilize Let's Encrypt issued certificate when accessing the Pihole Admin page.
After the upgrade to v6, server2.xxxxxxxxx.com is now resolving to 172.16.100.203 and longer resolving to 172.16.100.1 (reverse proxy) and also presented with a self-signed cert when accessing the admin page.
https://tricorder.pi-hole.net/vU4sVjuh/
during the upgrade pihole create a self-signed cert. TLS/SSL - Pi-hole documentation. Instruction on how to use your own is at the bottom. You have to make a few changes. This is how I did mine Own TLS certificate not used - Help - Pi-hole Userspace
Everything was working prior to the upgrade. I would prefer to use Let’s Encrypt issued Certificates over Self signed.
I also use LE. Instructions was provided. Anway good luck
test with this in edit proxy host / advanced :slight_smile:
location / {
proxy_pass http://host:ip/admin/;
proxy_set_header Host $host;
proxy_set_header X-Real-IP $remote_addr;
proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
proxy_hide_header X-Frame-Options;
proxy_set_header X-Frame-Options "SAMEORIGIN";
proxy_read_timeout 90;
location /admin/ {
location /api/ {
proxy_pass http://host:ip/api/;
tell me
Thanks. I can simply create an entry (172.16.100.1 server2.xxxxxxxxx.com) to the host file on the computer I am going to be using to manage Pi-Hole and problem will be solved. However, we're in the 21st century :grimacing: defeats the purpose of using a DNS server.
Can I put this in NGINX PROXY MANAGER? Or should I change something? I ask because I tried to put these settings in the advanced tab, but it only generated errors.
You must change the "host:ip" part by replacing it with ip:port of the Pi-hole.
