I don't know why so many requests and failing..
-Raspbian runing Pi-hole 5.0
-RaspberryPi 3b+
Lots of reverse lookups SERVERFAIL during the night..
Also my Pi-hole is working as DHCP and DNS. Why when does it shows this:
pi@raspberrypi:~ $ cat /etc/resolv.conf
Dynamic resolv.conf(5) file for glibc resolver(3) generated by resolvconf(8)
DO NOT EDIT THIS FILE BY HAND -- YOUR CHANGES WILL BE OVERWRITTEN
nameserver 192.168.1.254
nameserver 2001:8a0:574c:e301:4d99:d1e0:7c76:4db3
search amor
pi@raspberrypi:~ $
The Pi-hole IP is 192.168.1.88
I edited /etc/dhcpcd.conf to make the static domain_name_servers=192.168.1.88 and after a reboot the /etc/resolv.conf stuck with the right nameserver=192.168.1.88 that is of the Pi-hole.
Selecting DNS 127.0.0.1#5053 (DNS over HTTPS) again brought back the SERVERFAIL queries.
It looks like is only on reverse lookbacks.
Should I ignore this?
