Restrict access to web interface by IP
Hello all,
I'm using Pi-hole Version v4.3.1 Web Interface Version v4.3 FTL Version v4.3.1 inside my 192.168.178.*-intranet and love it. I'd like to exclude anyone else from the outside to have any access to the Web Interface.
So I appended
# https://www.cyberciti.biz/tips/lighttpd-restrict-or-deny-access-by-ip-address.html
# https://discourse.pi-hole.net/t/password-protect-the-dashboard/223/5
# restrict access to server-status to listed IP hosts
$HTTP["remoteip"] !~ "192.168.178.10|192.168.178.20" {
    $HTTP["url"] =~ "^/admin/" {
      url.access-deny = ( "" )
to /etc/lighttpd/lighttpd.conf. Though two sources suggested that syntax, lighttpd complains
sudo service lighttpd restart
sudo service lighttpd status
● lighttpd.service - Lighttpd Daemon
   Loaded: loaded (/lib/systemd/system/lighttpd.service; enabled; vendor preset: enabled)
   Active: active (running) since Thu 2019-08-01 11:58:48 CEST; 5s ago
  Process: 4120 ExecStartPre=/usr/sbin/lighttpd -tt -f /etc/lighttpd/lighttpd.conf (code=exited, status=0/SUCCESS)
 Main PID: 4127 (lighttpd)
    Tasks: 6 (limit: 2200)
   Memory: 5.9M
   CGroup: /system.slice/lighttpd.service
           β”œβ”€4127 /usr/sbin/lighttpd -D -f /etc/lighttpd/lighttpd.conf
           β”œβ”€4137 /usr/bin/php-cgi
           β”œβ”€4138 /usr/bin/php-cgi
           β”œβ”€4139 /usr/bin/php-cgi
           β”œβ”€4140 /usr/bin/php-cgi
           └─4141 /usr/bin/php-cgi
Aug 01 11:58:48 raspberrypi systemd[1]: Starting Lighttpd Daemon...
Aug 01 11:58:48 raspberrypi lighttpd[4120]: 2019-08-01 11:58:48: (server.c.1493) WARNING: unknown config-key: alias.url (ignored)
Aug 01 11:58:48 raspberrypi systemd[1]: Started Lighttpd Daemon.
What do I miss?
Another post that deals with WARNING: unknown config-key: alias.url (ignored) suggests to include mod_alias so I changed the original /etc/lighttpd/lighttpd.conf from
server.modules = (
        "mod_access",
        "mod_accesslog",
        "mod_auth",
        "mod_expire",
        "mod_compress",
        "mod_redirect",
        "mod_setenv",
        "mod_rewrite"
to
server.modules = (
        "mod_access",
        "mod_accesslog",
        "mod_alias",
        "mod_auth",
        "mod_expire",
        "mod_compress",
        "mod_redirect",
        "mod_setenv",
        "mod_rewrite"
which did the trick.
:smiley:
This /etc/lighttpd/lighttpd.conf file will get overwritten when you run Pi-hole repair/reconfigure or apt upgrade.
Try put as many customized options as possible in the /etc/lighttpd/external.conf file which doesnt get overwritten:
pi@noads:~ $ tail -3 /etc/lighttpd/lighttpd.conf
# Add user chosen options held in external file
# This uses include_shell instead of an include wildcard for compatibility
