The setup
I have a Raspi3B running pi-hole at address 192.168.0.116
. DHCP is turned off there. At address 192.168.0.1
I have a router running that poses as dhcp server. The local network suffix is fritz.box
The problem
When trying to resolve a local hostname, two IP adresses get reported back. I have e.g. a host named raspberrypi4.fritz.box
running at address 192.168.0.48
. However if I do a nslookup raspberrypi4.fritz.box
on the machine itself the output is:
pi@raspberrypi4:~ $ nslookup raspberrypi4.fritz.box
Server: 192.168.0.116
Address: 192.168.0.116#53
Address: 192.168.0.35
Address: 192.168.0.48
This leads to having long access times to the local devices as sometimes the wrong address, in this case 192.168.0.35
is returned first and a timeout has to occur.
Does anybody know how to debug where the wrong address is coming from? A dig
call returns the following:
pi@raspberrypi4:~ $ dig raspberrypi4.fritz.box
; <<>> DiG 9.11.5-P4-5.1-Raspbian <<>> raspberrypi4.fritz.box
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 315
;; flags: qr aa rd ra; QUERY: 1, ANSWER: 2, AUTHORITY: 1, ADDITIONAL: 1
;raspberrypi4.fritz.box. IN A
raspberrypi4.fritz.box. 9 IN A 192.168.0.35
raspberrypi4.fritz.box. 9 IN A 192.168.0.48
;; AUTHORITY SECTION:
raspberrypi4.fritz.box. 9 IN NS fritz.box.
;; ADDITIONAL SECTION:
fritz.box. 9 IN A 192.168.0.1
;; Query time: 5 msec
;; SERVER: 192.168.0.116#53(192.168.0.116)
;; WHEN: Sat Jun 13 20:59:37 CEST 2020
;; MSG SIZE rcvd: 102
The same command on the pihole system yields:
pi@raspberrypi:~ $ dig raspberrypi4.fritz.box
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 54096
;; Query time: 11 msec
;; WHEN: Sa Jun 13 21:02:47 CEST 2020
I already tried flushing the ARP cache on the pi-hole system using
sudo ip -s -s neigh flush all
The /etc/hosts
file of the pi-hole system contains
127.0.0.1 localhost
::1 localhost ip6-localhost ip6-loopback
ff02::1 ip6-allnodes
ff02::2 ip6-allrouters
127.0.1.1 raspberrypi
