instead of lighttpd
Resolver working for ping, to upload log files.
resolver not running.
Does not resolve ie ping google.com.
Cannot upload the pihole -d log.
curl failed.
netcat " Temporary failure in name resolution".
using pihole -r cannot download the new FTL engine
Log file is sitting on my Raspberrypi, cannot upload due to resolver error
