[RESOLVED] Pihole -up breaks installation, lighttpd not starting and DNS service stopped
Update to v5.15.5 with pihole -up.
Had similar issues and updated to 5.15.5 but now I am greeting by a 403 error in the browser. Bright side lighttp is up and running :smiley:
Thank you @DanSchaper Your fix is legendary, as is your ability to help us when things go wrong. eveything is working now, and you are a great guy. Thank you so much.
P
That's expected. The release notes for v5.15 explain it but you need to use the full ip/admin URL if you don't use pi.hole.
Appreciate the complement but it's a full team, not just me. :slight_smile:
I know but I love you the most. The rest of the team will have to deal with it.
Its 100% working after applying the second update so hopefully other people realize to update twice if they updated during the moments it was broken.
just created an account to say: well done Dan! That's a quickfix :wink:
Had the same issue on a RPI3.
I was so fixed on the other issue that I didnt even check the proper URL ... me feel stupid :no_mouth:
Everything works perfectly fine now. Donation incoming :partying_face:
Yeah, some of us break things too! :dotted_line_face:
You need to add /admin.
Are you accessing the web interface using http://IPaddress/admin or http://pi.hole/admin?
Thank you very much for the quick fix, now the update worked as expected! :top:
