My raspberry pi died so I am now installing from scratch on macOS with Docker Desktop.
I tried using the example docker compose file with network_mode: host but even after setting the FTLCONF_LOCAL_IPV4 to my macOS IP address I still cannot access the web interface.
If I try the docker default network and expose the TCP+UDP ports I am able to access the web interface and resolve DNS via the container, but the clients IP addresses are all on the docker network gateway, so I don't have visibility of the different clients connecting on my DNS (I have extra block lists for the devices that my kids use).
Could someone please point me in the right direction?
services:
pihole:
container_name: pihole
hostname: pihole
image: pihole/pihole:2024.07.0
# network_mode: host
ports:
- 53:53/tcp
- 53:53/udp
- 5380:5380/tcp
environment:
TZ: Pacific/Auckland
WEBPASSWORD: 'password'
FTLCONF_LOCAL_IPV4: 192.168.1.200
VIRTUAL_HOST: pihole
PIHOLE_DNS_: '1.1.1.1#53;8.8.8.8#53'
WEB_PORT: 5380
# # https://discourse.pi-hole.net/t/conditional-forwarding-not-providing-client-names-in-docker/64399/3
# Still not resolving anything
# REV_SERVER: true
# REV_SERVER_TARGET: 192.168.1.1
# REV_SERVER_CIDR: 192.168.1.0/24
volumes:
- pihole-etc:/etc/pihole/
- pihole-dsmasq:/etc/dnsmasq.d/
# changing lighttpd conf to expose port 5380 instead of 80 so it doesn't conflict with traefik
- ./portchange.conf:/etc/lighttpd/conf-enabled/20-portchange.conf
cap_add:
- NET_ADMIN
- CAP_NET_BIND_SERVICE
- CAP_NET_ADMIN
- CAP_NET_RAW
- CAP_CHOWN
restart: unless-stopped
volumes:
pihole-etc:
pihole-dsmasq:
✗ docker version
Client:
Version: 27.4.0
API version: 1.47
Go version: go1.22.10
Git commit: bde2b89
Built: Sat Dec 7 10:35:43 2024
OS/Arch: darwin/arm64
Context: desktop-linux
Server: Docker Desktop 4.37.2 (179585)
Engine:
Version: 27.4.0
API version: 1.47 (minimum version 1.24)
Git commit: 92a8393
Built: Sat Dec 7 10:38:33 2024
OS/Arch: linux/arm64
Experimental: false
containerd:
Version: 1.7.21
GitCommit: 472731909fa34bd7bc9c087e4c27943f9835f111
runc:
Version: 1.1.13
GitCommit: v1.1.13-0-g58aa920
docker-init:
Version: 0.19.0
GitCommit: de40ad0
