Requests from pi.hole without IP but ::
Hello,
I am running since a while pihole on docker and it works quite well. During the time I've noticed quite a lot request from pi.hole with the IP :: and I do not understand if this is a normal behaviour?
By the queries list for pi.hole :: it seems like the request coming from my home pc (archlinux).
The home pc is listed - in pihole - as expected by the ipv4 and ipv6 address.
Under the home pc network :: is not mentioned.
Is there anything wrong with my setup?
Are those requests normal?
Even if, why they get logged if under the queries page there is a note that states "Queries for pi.hole and the hostname are never logged."?
Thank you in advance for any suggestions or hints in this regard.
They are completely normal if you enable DNSSEC within Pi-hole, related to Pi-hole's DNSSEC validation, see also
Thank you very much!
Didn't know what I could search for.
Yeah DNSSEC is enabled. Thanks again for pointing me to the right topic.
