update web portion of pihole to the ftl branch
pihole checkout web FTLDNS
Please note that changing branches severely alters your Pi-hole subsystems
Features that work on the master branch, may not on a development branch
This feature is NOT supported unless a Pi-hole developer explicitly asks!
Have you read and understood this? [y/N] y
I've somehow fixed the initial problem but it seems that (or something else) broke something else. If I pihole -v I get:
Pi-hole version is v3.3-65-g295ac49 (Latest: v3.3)
AdminLTE version is v3.2.1-80-g517fa24f (Latest: v3.3)
FTL version is vDev-a26da52 (Latest: v3.0)
pihole -up tells me
[i] Checking for updates...
[i] Pi-hole Core: up to date
[i] FTL: update available
[i] FTL out of date
[i] FTL Checks...
[✓] Detected x86_64 architecture
[✓] Downloading and Installing FTL
[i] Web Interface: up to date
[i] FTL version is now at
[✓] Starting pihole-FTL service
[✓] Enabling pihole-FTL service to start on reboot
but no matter how often I try to update, the output stays the same.
Thanks for the follow up - As I've had the feeling something really bad happened I've restored the whole VM to the point it was yesterday (before the upgrade to the FTL beta).
So please take the initial post as the actual status again please:
cd /var/www/html/admin
strn@piDNS:/var/www/html/admin$ sudo git fetch --all
Fetching origin
strn@piDNS:/var/www/html/admin$ pihole checkout web FTLDNS
I can pretty much destroy everything if I have to. I can restore the vm in case of atomic radiation very quickly ...
strn@piDNS:/var/www/html/admin$ sudo rm -rf /var/www/html/admin
strn@piDNS:/var/www/html/admin$ sudo git clone https://github.com/pi-hole/AdminLTE.git /var/www/html/admin
fatal: Could not get current working directory: No such file or directory
strn@piDNS:/var/www/html/admin$ cd /
strn@piDNS:/$ sudo git clone https://github.com/pi-hole/AdminLTE.git /var/www/html/admin
Cloning into '/var/www/html/admin'...
remote: Counting objects: 17452, done.
remote: Compressing objects: 100% (21/21), done.
remote: Total 17452 (delta 8), reused 18 (delta 6), pack-reused 17425
Receiving objects: 100% (17452/17452), 24.74 MiB | 2.63 MiB/s, done.
Resolving deltas: 100% (9111/9111), done.
strn@piDNS:/$ sudo git checkout FTLDNS
fatal: Not a git repository (or any of the parent directories): .git
dunno if it helps:
strn@piDNS:/$ pihole -v
Pi-hole version is v3.3-rc1-114-g295ac49 (Latest: v3.3)
AdminLTE version is v3.3 (Latest: v3.3)
strn@piDNS:/var/www/html/admin$ sudo git checkout FTLDNS
Branch FTLDNS set up to track remote branch FTLDNS from origin.
Switched to a new branch 'FTLDNS'
strn@piDNS:/var/www/html/admin$ pihole checkout core FTLDNS
[✓] Fetching branches from https://github.com/pi-hole/pi-hole.git
[i] 36 branches available for Pi-hole Core
[✓] Switching to branch: 'FTLDNS' from 'refs/heads/FTLDNS'
[i] Already up-to-date.
[i] Running installer to upgrade your installation
[✓] Root user check
[✓] Fetching branches from https://github.com/pi-hole/AdminLTE.git
[i] 18 branches available for Web Admin
strn@piDNS:/var/www/html/admin$ pihole -v
GUI is working again, checkout worked like it should I guess.
Should the version namings look how they should be I can confirm that you solved the puzzle, great job jacob - thank you
