Repeated errors
I don’t know if this is the right place for this, but I did a debug and it said to upload it here with the token.
https://tricorder.pi-hole.net/8hLeeGU9/
What errors do you see that are of concern?
Sorry, I deleted them. I thought the log would show? I get about 6 a week. I’ll try reporting again as soon as I see them.
Thank you.
Are you referring to these warnings?
*** [ DIAGNOSING ]: Pi-hole diagnosis messages
   count   last timestamp       type                  message                                                       blob1                 blob2                 blob3                 blob4                 blob5
   1       2022-07-14 11:57:30  DNSMASQ_WARN          ignoring query from non-local network 71.202.52.118 (logged
                                                      only once)
   1       2022-07-17 17:03:04  DNSMASQ_WARN          no address range available for DHCP request via lo
   1       2022-07-17 17:03:04  DNSMASQ_WARN          not using configured address 192.168.0.51 because it is in u
                                                      se by the server or relay
   3       2022-07-15 12:31:47  DNSMASQ_WARN          reducing DNS packet size for nameserver 127.0.0.1 to 1232
   1       2022-07-17 00:20:27  LOAD                  excessive load                                                4.44                  4
   1       2022-07-16 23:12:06  RATE_LIMIT            192.168.0.53                                                  1000                  60
Yes, especially the reducing DNS packet size and the excessive load.
I don’t know how a “non-local network” could get to my raspberry pi.
And I am assuming that the overload is due to some website trying to slam me with requests?
Take a look at our dnsmasq warnings page. It will explain these messages, with the exception of the load and rate limits.
Look in your query log for a query from that first IP. It's a comcast IP, likely from your router, which is not normally a concern.
nslookup 71.202.52.118
118.52.202.71.in-addr.arpa	name = c-71-202-52-118.hsd1.ca.comcast.net.
Excessive load can be something as simple as you running a gravity update. On a low-powered system, this can max out the CPU. You can disable that check if you don't want to see this warning:
The rate limit shows that the client at IP 53 exceeded the default rate limit of 1000 queries in 60 seconds. This limit is also adjustable, and is discussed here:
Thank you very much! You have been extremely helpful!
