@codinghorror Just in case you missed it.
That's great! Thank you!! Where to paypal the $250 funds to?
You may want to check it does what you're expecting, first.. Donations are a nice, although secondary concern
If you're running something on the dev branch already then you can test out by running:
pihole checkout ftl new/unlink_DHCP_lease
pihole checkout web new/unlink_DHCP_lease
If you're not already running on the dev
branches, please be aware that doing so will make going back to master
more difficult because of some breaking differences in the database schema (until we release the next version). But if you want to do it, take a backup of your /etc/pihole
directory and then run pihole checkout dev
, followed by the two commands above for checking out the individual branches. Then, when/if you want to switch back from dev
, run pihole checkout master
and restore your backed up /etc/pihole
directory.
(or just do a fresh install on a VPS if you're worried about data loss)
I'm fine waiting for it to release on stable, appreciated! As long as the UI element is there (red trashcan button) and it does what you'd expect (removes the lease when pressed), I'm good!
Thanks for all your hard work on this project @DL6ER @PromoFaux -- and let me know where to send the PayPal!
No... thank you (and all our users!) for using, and supporting the project
Donate β Pi-hole , thanks!
This has been released with
