Hi there,
when i externally change the blacklist.txt or whitelist.txt (via a git pull in a crontab), is there a way to tell pi-hole to reload these 2 without downloading & refreshing the entire gravity.list?
git pull
Or do i just need to pihole -g every time?
pihole -g
Thanks.
When you update gravity, only the lists that have changed are downloaded. For unchanged lists, a local copy is used.
If you update black or whitelists through Pi-Hole, gravity is run as follows:
Thanks for your reply,
it seems i could also do pihole -g --skip-download --blacklist-only , when for example updating only the blacklist.
Will test this later, thanks again.
