Hi all,
I run proxmox, and give the machines names that I want to appear in the local DNS.
I've searched the docs and forums, but don't see an official solution.
ChatGPT sats, Pi-hole's official API doesn't yet support adding Local DNS Records directly. But if you're using Pi-hole v5.0+, you can directly modify /etc/pihole/custom.list and then reload DN
So, I was thinking of the following.. what do you think?
#!/bin/bash
# Config
PIHOLE_HOST="pi.hole.local" # or IP of your Pi-hole
PIHOLE_USER="pi" # SSH user on Pi-hole
PIHOLE_CUSTOM_LIST="/etc/pihole/custom.list"
TMPFILE="/tmp/custom.list"
# Create a temp file with updated DNS entries
> "$TMPFILE"
for cid in $(pct list | awk 'NR>1 {print $1}'); do
name=$(pct config "$cid" | grep ^hostname | awk '{print $2}')
ip=$(pct exec "$cid" -- hostname -I | awk '{print $1}')
echo "$ip $name.lan" >> "$TMPFILE"
done
# Send to Pi-hole and reload DNS
scp "$TMPFILE" "$PIHOLE_USER@$PIHOLE_HOST:/tmp/custom.list"
ssh "$PIHOLE_USER@$PIHOLE_HOST" "sudo mv /tmp/custom.list $PIHOLE_CUSTOM_LIST && sudo pihole restartdns"
echo "✔️ Updated Pi-hole DNS with LXC entries."
Thanks, Martin
