I am new to Pi-Hole and expressions.
I would like to block as many as possible youtube adds.
I noticed, that many adds are coming from links like:
-> rr2---sn-5goeen7y.googlevideo.com
-> rr1---sn-5goeen7y.googlevideo.com
I would expect, that my expression will block them:
rr\d{1,}-{3,}sn-\S{8}.googlevideo.com
However, all googlevideo requests seems to pass through.
|Time|Type|Domain|Client|Status|Reply|Action|
2022-05-15 21:28:38 A rr3---sn-5go7yne6.googlevideo.com 192.xyz.ab.cd OK, answered by dns.opendns.com#53 CNAME (56.8ms)
What I am doing wrong?
Can you please help, how to block this crap ?
sorry do not know how to do it.
Please let me know, if you need more info.
Buy a youtube subscription. Honestly: search this forum, there have been a lot of attempts to block youtube ads but all in vain. YT servers ads from the same domains as the ads. If you block them, you also block the video content.
I am aware of if, but why expression is not working on pihole ?
That is what I do not understand. In a way it should work and it should be blocked following blacklisted expressions.
Not quite.
We don't ask you do publically post your debug log, because it contains potentially sensitive information (note that commonly, the private range IP addresses that you chose to redact from your log would be safe to share).
Instead, we ask to upload a debug log to our tricorder where only trusted members of the Pi-hole team may access it, and where it autodeletes after 48 hours.
We'd then just need the token to access it.
Your
would match rr2---sn-5goeen7y.googlevideo.com (as can be verified by testing your RegEx).
Also, you should consider to remove all non-domain entries from your blocklists (e.g. all entries starting with https:), as those are useless for domain filtering.
