RegEx engine improvements
I rebased this branch on the current beta branch.
testing (ran pihole checkout ftl new/regex_replytype). first test result here, due to topic relevance.
edit
thus tested reply=ip, dig result:
; <<>> DiG 9.16.4 <<>> fuk01.ps4.update.playstation.net
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 19237
;fuk01.ps4.update.playstation.net. IN   A
fuk01.ps4.update.playstation.net. 2 IN  A       192.168.2.57
;; Query time: 4 msec
;; SERVER: 192.168.2.57#53(192.168.2.57)
;; WHEN: Fri Sep 10 09:55:10 Romance Daylight Time 2021
;; MSG SIZE  rcvd: 77
tested reply=nodata, dig result:
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 14311
;; Query time: 6 msec
;; WHEN: Fri Sep 10 10:35:18 Romance Daylight Time 2021
;; MSG SIZE  rcvd: 61
tested reply=nxdomain, dig result:
;; ->>HEADER<<- opcode: QUERY, status: NXDOMAIN, id: 28488
;; Query time: 5 msec
;; WHEN: Fri Sep 10 10:41:36 Romance Daylight Time 2021
all modes tested and working, replies as expected.
/edit
edit2
with (\.|^)ps4\.update\.playstation\.net$;reply=ip
dig AAAA fuk01.ps4.update.playstation.net
; <<>> DiG 9.16.4 <<>> AAAA fuk01.ps4.update.playstation.net
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 51782
;fuk01.ps4.update.playstation.net. IN AAAA
fuk01.ps4.update.playstation.net. 2 IN AAAA 2a02:xxxx:yyyy:zzzz:9435:92d8:531d:b64a
;; WHEN: Fri Sep 10 14:32:23 Romance Daylight Time 2021
;; MSG SIZE rcvd: 89
so this also produces a correct response.
/edit2
Thanks for your testing, the feature PR can be found here:
https://github.com/pi-hole/FTL/pull/1159
I should mention there is another option:
;reply=none
The new feature has already been reviewed and approved. It'll be part of the next Pi-hole release and is already part of the currently running beta.
Documentation update still outstanding.
Has been implemented in
