Set-up
Here is my situation:
- one modem in bridge mode, connected to one router (gl.inet flint) with lan and guest wifi networks;
- on lan network, laptops and phones;
- on guest network, smartTV and smart radio;
- the router is set to use pi-hole for dns on both lan and guest networks.
All devices, both on lan and guest, should use pi-hole for DNS and get filtered accordingly
At first, all devices work properly, but only the ones on lan appear in pi-hole, leading me to think that the smarttv and smart radio actually bypass pi-hole with hardcoded dns.
What I did
I used this and this to create rules to redirect all dns requests to the pi.
When i first opened the "firewall - port forwards" of the advanced settings panel (luci), I saw there were already two unnamed rules that forced dns to the router (and the router is set to use pi-hole for both lan and guest). When only those rules are used, we get the "actual behaviour".
I added a rule in line with the first guide. Since offenders are only on the guest network, I added a rule as follows (the last one, unchecked):
It occured to me afterwards that the "!192.168.8.101" exception is moot, as the pi is not on the guest network (which is 192.168.9.XX), but it won't hurt.
I also added a NAT rules as follows:
After testing, having the NAT rule or not seems to have an impact. However, activating the third port forward rule (instead of the second) breaks the connection: the radio won't start, and the TV mostly won't work. However, the TV gets picked up by the pi (the radio does not appear at all).
I also get a lot of those requests:
First of all, there is one thing I am unsure about: in that third port forward rule, it is right to put "forward to lan" with the pi's address, right?
Secondly, well... how come everything breaks? I mean, I have a blocklist for the smarttv, so that might break things, but disabling it is not fixing the radio, so that doesn't seem like the problem -- while deactivating rule 3 and activating rule 2 fixes the radio instantly. Any ideas?
Thanks a lot!
PS: I come to realise this is more of a router issue and less of a pi-hole issue, but I have seen similar situations addressed in other posts of this forum, and I feel the answer might be useful to others too
