Recommended adlists to use 2024
Just need some recommended sites to use for ad-listing currently i used a blog from cross talk solutions to setup pi-hole on Raspberry pi3# and i am using some of the URL links from the site firebug
see screenshot. .
https://imgur.com/a/OXolFmT
I'm really not sure that there is a recommended set of ad block lists to use, let alone ones tied to a particular year.
My suggestion would be to use the default list, and perhaps any others that are maintained on a regular basis. A lot of lists overlap, so there is likely a point of diminishing returns. Also, you may start finding that you incorporate a list that blocks some content you may want to see, but the list creator does not.
I like to use the Mullvad blocklists.
These are the lists i currently use and work really well, 313,732 domains on adlists
:sunglasses:
https://raw.githubusercontent.com/PolishFiltersTeam/KADhosts/master/KADhosts.txt
https://raw.githubusercontent.com/FadeMind/hosts.extras/master/add.Spam/hosts
https://v.firebog.net/hosts/static/w3kbl.txt
https://adaway.org/hosts.txt
https://v.firebog.net/hosts/AdguardDNS.txt
https://v.firebog.net/hosts/Admiral.txt
https://v.firebog.net/hosts/Easyprivacy.txt
https://v.firebog.net/hosts/Prigent-Ads.txt
https://raw.githubusercontent.com/anudeepND/blacklist/master/adservers.txt
