To reduce duplicate questions please be sure to try searching for a similar problem first and looking through the FAQs. Thank you!
If you do have a problem that is not solved after review, please post a detailed description of your problem along with the output from the command pihole -d. This will help speed things up tremendously.
Thanks for reading, and thanks for using the Pi-hole!
