Raspbian: FTL Engine installation failure, Feb 2020
I'm running latest updated Raspbian Buster lite on Pi4 4GB. The installation fails in middle with below pasted logs. The pihole doesn't get installed at all, so no "pihole" command is available either.
Should be getting final "Installation complete" page, but
[i] Web Server On
[i] Logging On.
[✗] Check for existing repository in /etc/.pihole
[✓] Clone https://github.com/pi-hole/pi-hole.git into /etc/.pihole
[✗] Check for existing repository in /var/www/html/admin
[✓] Clone https://github.com/pi-hole/AdminLTE.git into /var/www/html/admin
[i] Main Dependency checks...
[✓] Checking for cron
[✓] Checking for curl
[i] Checking for dnsutils (will be installed)
[✓] Checking for iputils-ping
[i] Checking for lsof (will be installed)
[i] Checking for netcat (will be installed)
[✓] Checking for psmisc
[✓] Checking for sudo
[✓] Checking for unzip
[✓] Checking for wget
[i] Checking for idn2 (will be installed)
[i] Checking for sqlite3 (will be installed)
[✓] Checking for libcap2-bin
[i] Checking for dns-root-data (will be installed)
[i] Checking for resolvconf (will be installed)
[i] Checking for lighttpd (will be installed)
[i] Checking for php-common (will be installed)
[i] Checking for php-cgi (will be installed)
[i] Checking for php-sqlite3 (will be installed)
[✓] Enabling lighttpd service to start on reboot...
[i] FTL Checks...
[✓] Detected ARM-hf architecture (armv7+)
Error: Unable to get latest release location from GitHub
[✗] FTL Engine not installed
pi@raspberrypi:~ $
pi@raspberrypi:~ $ pihole -d
-bash: pihole: command not found
This will temporarily reset the nameserver on the Pi to bypass Pi-Hole DNS.
sudo nano /etc/resolv.conf
edit nameserver 127.0.0.1 to nameserver 9.9.9.9 or your preferred third party DNS service, save and exit
Run the installer again.
Thanks for your reply !!
I can't do install again as it won't take any pihole command or fresh install command either
pi@raspberrypi:~ $ sudo nano /etc/resolv.conf
pi@raspberrypi:~ $ pihole -r
pi@raspberrypi:~ $ curl -sSL https://install.pi-hole.net | bash
curl: (6) Could not resolve host: install.pi-hole.net
This happens after trying pihole install once and then changing resolv.conf
What is in resolv.conf now?
cat /etc/resolv.conf | grep nameserver
What are the results of a dig for pi-hole.net from the Pi terminal
dig install.pi-hole.net
I tried fresh install of raspbian and hence pihole.
nameserver before pihole install was set to 8.8.8.8 but after install failed the config file was blank. Did set it to google DNS again and then ran DIG command
   pi@raspberrypi:~ $ dig install. pi-hole. net
; <<>> DiG 9.11.5-P4-5.1-Raspbian <<>> install.pi-hole.net
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 16081
;; flags: qr rd ra; QUERY: 1, ANSWER: 2, AUTHORITY: 0, ADDITIONAL: 1
;install.pi-hole.net. IN A
install.pi-hole.net. 3599 IN CNAME guinan.pi-hole.net.
guinan.pi-hole.net. 3599 IN A 78.46.180.80
;; Query time: 95 msec
;; SERVER: 8.8.8.8#53(8.8.8.8)
;; WHEN: Wed Feb 05 03:28:18 GMT 2020
;; MSG SIZE rcvd: 85
  1. pihole not found
  2. Even though
pi@raspberrypi:~ $ cat /etc/resolv.conf | grep nameserver
nameserver 8.8.8.8
Now run the install curl script again.
now apt-get update command is misbehaving too
pi@raspberrypi:~ $ sudo apt-get update
Err:1 http://raspbian.raspberrypi. org/raspbian buster InRelease
Temporary failure resolving 'raspbian. raspberrypi . org'
Err:2 http://archive.raspberrypi.org/debian buster InRelease
Temporary failure resolving 'archive. raspberrypi .org'
Reading package lists... Done
W: Failed to fetch http://raspbian. raspberrypi. org/raspbian/ dists/buster/InRelease Temporary failure resolving 'raspbian.raspberrypi .org'
W: Failed to fetch http://archive.raspberrypi. org/debian/dists/buster/InRelease Temporary failure resolving 'archive.raspberrypi. org'
W: Some index files failed to download. They have been ignored, or old ones used instead.
This isn't a Pi-Hole problem at this point. Pi-Hole is not installed, your Pi can't reach the internet reliably using a third party nameserver. Check your ethernet cable if you are using one. What are you using for a power supply on the Pi-4?
What is the output of the following from the Pi:
ping -c3 8.8.8.8
ping -c3 google.com
ip addr
I'hv connected Pi using lan cable directly to my router (100 mbps). Using 5v 2A powersupply through type C port.
pi@raspberrypi:~ $ ping -c3 8.8.8.8
PING 8.8.8.8 (8.8.8.8) 56(84) bytes of data.
64 bytes from 8.8.8.8: icmp_seq=1 ttl=57 time=8.35 ms
64 bytes from 8.8.8.8: icmp_seq=2 ttl=57 time=8.34 ms
64 bytes from 8.8.8.8: icmp_seq=3 ttl=57 time=8.41 ms
--- 8.8.8.8 ping statistics ---
3 packets transmitted, 3 received, 0% packet loss, time 5ms
rtt min/avg/max/mdev = 8.338/8.367/8.410/0.080 ms
pi@raspberrypi:~ $ ping -c3 google.com
ping: google.com: Temporary failure in name resolution
pi@raspberrypi:~ $ ip addr
    inet6 ::1/128 scope host
2: eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP group default qlen 1000
    link/ether dc:a6:32:20:eb:23 brd ff:ff:ff:ff:ff:ff
    inet 192.168.1.119/24 brd 192.168.1.255 scope global noprefixroute eth0
    inet6 fe80::aba1:67d4:1b81:ccc9/64 scope link
3: wlan0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc pfifo_fast state DOWN group default qlen 1000
    link/ether dc:a6:32:20:eb:24 brd ff:ff:ff:ff:ff:ff
That is an inadequate power supply for that device. Raspberrypi.org specifies 15 watts, or 3 amps at 5V.
"* A good quality 2.5A power supply can be used if downstream USB peripherals consume less than 500mA in total."
You are short of both.
I think power supply is right because I have another Pi4 with same power supply and running OMV with HDD attached to USB.
Anyway, I got it. Somehow the nameserver was resetting back to 127.0.0.1.This time I tried 1.1.1.1 and then restarted pi(didn't restart earlier at all). Afterwards Curl command ran fine.
Good that it's sorted now. But, if you are running an inadquate power supply, you will soon have SD card failures. With inadequate power, the Pi won't write properly to the card. It may run for now, but it will fail early with inadequate power.
ohk..Thanks for info. I'll change them soon.
I am having the exact same problems on clean image Raspbian install on RPi3b+. I've tried new SD cards, a new power adapter, and even a new RPi3b+, without any luck. The install script seems to set DNS 127.0.0.1 "too early", and the rest of the script fails. If I set DNS to i.e. 8.8.8.8, I can now retry the install script, and it will succeed. But the Pi-hole installation will mess up the Raspbian system, eth0 has lots of problems, and in my case it always ends in system crash (kernel panic?).
I created a new post explaining my problems: [RESOLVED] Endless problems with Pi-hole after Raspbian 2020-02-05 update
And yes, this started immediately after the Feb 2020 Raspbian update.
