New Pi Zero W, new 32GB SD card, new install of Raspberry Pi OS (Bookworm) Lite 32 bit
Installer should run to completion and Pi-Hole appear on the network.
Installer exited at static IP message, Pi-Hole not running
What I did to get here:
- Installed the OS with Raspberry Pi imager using custom data to connect to wifi.
- Logged in with SSH via wifi
- Updated and Upgraded the OS.
- Rebooted.
- Ran the install script copied from Installation - Pi-hole documentation
- Rebooted
Result:
- Bash does not recognise pihole command eg "pihole -up"
- Pointing a browser on network to http://192.168.1.194/admin/ gets the response "This site can't be reached"
This is the SSH console log:
~ $ curl -sSL https://install.pi-hole.net | bash
[i] Root user check
[i] Script called with non-root privileges
The Pi-hole requires elevated privileges to install and run
Please check the installer for any concerns regarding this requirement
Make sure to download this script from a trusted source
[✓] Sudo utility check
[✓] Root user check
.ccccc:,.
:cccclll:. ..,,
:ccccclll. ;ooodc
'ccll:;ll .oooodc
.;cll.;;looo:.
[i] SELinux not detected
[✓] Building dependency package pihole-meta.deb
[✓] Installing Pi-hole dependency package
[✓] Supported OS detected
[i] Installer exited at static IP message.
pi@myzero:~ $ pihole -up
-bash: pihole: command not found
Cannot provide Debug Token because pihole is not running
Am I doing something wrong? All help most welcome and gratefully received!
