I would like to move forward with setting up a PIE-HOLE in my environment.
Will Raspberry Pi Zero be enough? doesn't the Wi-Fi connection will make slow the connection from the devices in the LAN then using a wired connection with Raspberry Pi 4?
A Zero has plenty of power. Only the DNS traffic goes to the Pi-Hole (none of the data traffic), so a low power or WiFi device for Pi-Hole will not slow your network.
That's what I use. A Pi Zero W. I have it plugged into my routers USB port for power and it just sits there on top. Works a charm.
4 posts were split to a new topic: Pi-hole Admin interface not accessible
