Expected Behavior:
Raspberry Pi connects to the internet while server is running
Can view http://pi.hole/ for information regarding blocked ads
Actual Behavior:
Raspberry Pi cannot connect to the internet
Cannot reach http://pi.hole/ "ERR_NAME_NOT_RESOLVED"
None given after running pihole -d, due to non-upload since it cant connect to the internet. If I need to post any part or all of it let me know
Hello and thanks in advance for any advice given. I just got done installing Pi-Hole onto a new raspberry pi. I used netgear's genie to change all of the settings for the Pi to be the DNS used. However, after completing this task, the pi lost connection to the internet and after trying multiple other things from other forums, it still will not properly reconnect to the internet. I'm assuming that the 2nd issue is in result of the internet connection issues. It still says however when I ran pihole status that it is functioning properly and from pihole -v the version is 3.2.1 with the latest being an "ERROR" (again most likely due to the internet issue). If anyone has any ideas, please let me know.
I'm having the very same issue, and I've done what you've asked:
adblock@raspberrypi:~ $ traceroute 104.24.109.83
traceroute to 104.24.109.83 (104.24.109.83), 30 hops max, 60 byte packets
1 192.168.0.253 (192.168.0.253) 3159.129 ms !H 3158.971 ms !H 3158.945 ms !H
adblock@raspberrypi:~ $ cat /etc/resolv.conf
# Generated by resolvconf
search home
nameserver 127.0.0.1
adblock@raspberrypi:~ $ nslookup pi.hole localhost
Server: localhost
Address: ::1#53
Address: 192.168.1.17
I've set the pi-hole to use 192.168.0.253 (since I have a windows dhcp server on 254). I know that there's a "default gateway" listed as 192.168.1.1, but the entire subnet for all devices are on 192.168.0.1/24. I can ssh into the pi-hole, but I can't access the web interface (except once awkwardly when I tried fiddling with the router from Spectrum).
Server: localhost
Address: ::1#53
adblock@raspberrypi:~ $ pihole -d
This process collects information from your Pi-hole, and optionally uploads it to a unique and random directory on tricorder.pi-hole.net.
The intent of this script is to allow users to self-diagnose their installations. This is accomplished by running tests against our software and providing the user with links to FAQ articles when a problem is detected. Since we are a small team and Pi-hole has been growing steadily, it is our hope that this will help us spend more time on development.
*** [ INITIALIZING ]
[i] 2018-06-04:19:15:31 debug log has been initialized.
[i] Core: v3.3.1 (https://discourse.pi-hole.net/t/how-do-i-update-pi-hole/249)
[i] Branch: master
[i] Commit: v3.3.1-0-gfbee18e
[i] Web: v3.3 (https://discourse.pi-hole.net/t/how-do-i-update-pi-hole/249)
[i] Branch: master
[i] Commit: v3.3-0-ge48aa29
[✓] FTL: v3.0 (https://discourse.pi-hole.net/t/how-do-i-update-pi-hole/249)
*** [ DIAGNOSING ]: dnsmasq version
[i] 2.76
[i] 1.4.45
[i] 7.0.27
[✓] Raspbian GNU/Linux 9 (stretch)
*** [ DIAGNOSING ]: SELinux
[i] SELinux not detected
*** [ DIAGNOSING ]: Processor
/opt/pihole/piholeDebug.sh: line 474: $'[\E[32m✓\E[0m] \E[32marmv7l\E[0m': command not found
192.168.0.253/24 does not match the IP found in /etc/pihole/setupVars.conf (https://discourse.pi-hole.net/t/use-ipv6-ula-addresses-for-pi-hole/2127)
2605:e000:1313:208b:0:b148:1273:5dc1 does not match the IP found in /etc/pihole/setupVars.conf (https://discourse.pi-hole.net/t/use-ipv6-ula-addresses-for-pi-hole/2127)
fe80::cf73:42f8:cf8c:fc does not match the IP found in /etc/pihole/setupVars.conf (https://discourse.pi-hole.net/t/use-ipv6-ula-addresses-for-pi-hole/2127)
* Pinging 192.168.1.1...
[i] Default IPv6 gateway: fe80::3c11:64ff:fece:7ea8
* Pinging fe80::3c11:64ff:fece:7ea8...
[✓] Gateway responded.
[] is in use by
[22] is in use by sshd
[53] is in use by dnsmasq
[✓] urcarcleaning.be is 192.168.1.17 via localhost (127.0.0.1)
[✗] Failed to resolve urcarcleaning.be via Pi-hole (192.168.1.17)
[✓] dnsmasq daemon is active
[✗] lighttpd daemon is inactive
PIHOLE_INTERFACE=eth0
IPV4_ADDRESS=192.168.1.17/24
IPV6_ADDRESS=
QUERY_LOGGING=true
INSTALL_WEB=true
LIGHTTPD_ENABLED=1
DNSMASQ_LISTENING=single
PIHOLE_DNS_1=8.8.8.8
PIHOLE_DNS_2=8.8.4.4
PIHOLE_DNS_3=208.67.222.222
PIHOLE_DNS_4=208.67.220.220
DNS_FQDN_REQUIRED=true
DNS_BOGUS_PRIV=true
DNSSEC=false
CONDITIONAL_FORWARDING=false
[✗] X-Header does not match or could not be retrieved.
-rw-r--r-- 1 root root 4361359 Jun 4 19:04 /etc/pihole/gravity.list
192.168.1.17 0.0.0.0
192.168.1.17 0.r.msn.com
192.168.1.17 0.start.bz
192.168.1.17 000.gaysexe.free.fr
192.168.1.17 zzsyw.com
192.168.1.17 zztxdown.com
192.168.1.17 zzz.clickbank.net
192.168.1.17 zzzrtrcm2.com
-rw-r--r-- 1 root root 633 May 2 18:02 /etc/pihole/adlists.list
-rw-r--r-- 1 root root 46 Jun 4 19:04 /etc/pihole/local.list
192.168.1.17 raspberrypi
192.168.1.17 pi.hole
-rw-r--r-- 1 root root 234 May 2 18:01 /etc/pihole/logrotate
/var/log/pihole.log {
su root root
daily
copytruncate
rotate 5
compress
delaycompress
notifempty
nomail
/var/log/pihole-FTL.log {
su root root
weekly
copytruncate
rotate 3
compress
delaycompress
notifempty
nomail
-rw-r--r-- 1 root root 1577 Jun 4 18:20 /etc/dnsmasq.d/01-pihole.conf
localise-queries
no-resolv
cache-size=10000
log-queries=extra
local-ttl=2
log-async
server=8.8.8.8
server=8.8.4.4
server=208.67.222.222
server=208.67.220.220
domain-needed
bogus-priv
interface=eth0
-rw-r--r-- 1 root root 3027 May 2 18:01 /etc/lighttpd/lighttpd.conf
server.modules = (
"mod_access",
"mod_accesslog",
"mod_auth",
"mod_expire",
"mod_compress",
"mod_redirect",
"mod_setenv",
"mod_rewrite"
server.error-handler-404 = "pihole/index.php"
server.pid-file = "/var/run/lighttpd.pid"
server.username = "www-data"
server.groupname = "www-data"
server.port = 80
compress.filetype = ( "application/javascript", "text/css", "text/html", "text/plain" )
include_shell "/usr/share/lighttpd/create-mime.assign.pl"
' 2>/dev/null"
$HTTP["url"] =~ "^/admin/" {
"X-Frame-Options" => "DENY"
$HTTP["url"] =~ ".ttf$" {
url.access-deny = ("")
-rw-r--r-- 1 root root 1495 May 2 18:01 /etc/cron.d/pihole
8 3 * * 7 root PATH="$PATH:/usr/local/bin/" pihole updateGravity
00 00 * * * root PATH="$PATH:/usr/local/bin/" pihole flush once quiet
*/10 * * * * root PATH="$PATH:/usr/local/bin/" pihole updatechecker local
14 12 * * * root PATH="$PATH:/usr/local/bin/" pihole updatechecker remote
@reboot root PATH="$PATH:/usr/local/bin/" pihole updatechecker remote reboot
-rw-r--r-- 1 www-data www-data 2617 Jun 4 18:37 /var/log/lighttpd/error.log
2018-05-02 18:00:30: (log.c.217) server started
2018-05-02 18:01:58: (server.c.1828) server stopped by UID = 0 PID = 1
2018-05-02 18:01:58: (log.c.217) server started
2018-05-02 18:01:58: (server.c.1295) WARNING: unknown config-key: alias.url (ignored)
2018-05-02 18:04:58: (server.c.1828) server stopped by UID = 0 PID = 1
2018-05-02 18:05:18: (log.c.217) server started
2018-05-02 18:05:18: (server.c.1295) WARNING: unknown config-key: alias.url (ignored)
2018-06-04 14:55:18: (server.c.1828) server stopped by UID = 0 PID = 1
2018-06-04 14:55:32: (log.c.217) server started
2018-06-04 14:55:32: (server.c.1295) WARNING: unknown config-key: alias.url (ignored)
2018-06-04 14:58:12: (server.c.1828) server stopped by UID = 0 PID = 1
2018-06-04 14:58:21: (log.c.217) server started
2018-06-04 14:58:21: (server.c.1295) WARNING: unknown config-key: alias.url (ignored)
2018-06-04 15:31:51: (server.c.1828) server stopped by UID = 0 PID = 1
2018-06-04 15:32:08: (log.c.217) server started
2018-06-04 15:32:08: (server.c.1295) WARNING: unknown config-key: alias.url (ignored)
2018-06-04 15:39:03: (server.c.1828) server stopped by UID = 0 PID = 1
2018-06-04 15:39:23: (log.c.217) server started
2018-06-04 15:39:23: (server.c.1295) WARNING: unknown config-key: alias.url (ignored)
2018-06-04 16:43:28: (server.c.1828) server stopped by UID = 0 PID = 1
2018-06-04 16:43:39: (log.c.217) server started
2018-06-04 16:43:39: (server.c.1295) WARNING: unknown config-key: alias.url (ignored)
2018-06-04 16:43:55: (server.c.1828) server stopped by UID = 0 PID = 1
2018-06-04 16:44:13: (log.c.217) server started
2018-06-04 16:44:13: (server.c.1295) WARNING: unknown config-key: alias.url (ignored)
-rw-r--r-- 1 pihole pihole 29049 Jun 4 19:04 /var/log/pihole-FTL.log
[2018-06-04 16:43:09.151] Gravity list entries: 122436
[2018-06-04 16:43:09.151] No blacklist present
[2018-06-04 16:43:09.151] No wildcard blocking list present
[2018-06-04 16:43:09.151] read_data_from_DB() - SQL error prepare (5): database is locked
[2018-06-04 16:43:09.152] Reading from /var/log/pihole.log (rw-r--r--)
[2018-06-04 16:43:29.039] NOTICE: Received signal SIGHUP - re-reading gravity files
[2018-06-04 16:43:29.193] FATAL: FTL received SIGTERM from PID/UID 1/0, exiting gracefully
[2018-06-04 16:43:29.320] FATAL: FTL received SIGTERM from PID/UID 1845/0, exiting gracefully
[2018-06-04 16:43:29.463] Gravity list entries: 122436
[2018-06-04 16:43:29.609] No blacklist present
[2018-06-04 16:43:29.609] No wildcard blocking list present
[2018-06-04 16:43:29.610] -> Total DNS queries: 0
[2018-06-04 16:43:29.610] -> Cached DNS queries: 0
[2018-06-04 16:43:29.610] -> Forwarded DNS queries: 0
[2018-06-04 16:43:29.610] -> Exactly blocked DNS queries: 0
[2018-06-04 16:43:29.610] -> Wildcard blocked DNS queries: 0
[2018-06-04 16:43:29.610] -> Unknown DNS queries: 0
[2018-06-04 16:43:29.610] -> Unique domains: 0
[2018-06-04 16:43:29.610] -> Unique clients: 0
[2018-06-04 16:43:29.610] -> Known forward destinations: 0
[2018-06-04 16:43:29.610] Shutting down...
[2018-06-04 16:43:29.774] Finished final database update
[2018-06-04 16:43:36.107]
[2018-06-04 16:43:36.115] FTL branch: v3.0
-rw-r--r-- 1 dnsmasq root 2988051 Jun 4 19:18 /var/log/pihole.log
-----head of pihole.log------
Jun 4 16:43:29 dnsmasq[590]: exiting on receipt of SIGTERM
Jun 4 16:43:36 dnsmasq[495]: started, version 2.76 cachesize 10000
Jun 4 16:43:36 dnsmasq[495]: compile time options: IPv6 GNU-getopt DBus i18n IDN DHCP DHCPv6 no-Lua TFTP conntrack ipset auth DNSSEC loop-detect inotify
Jun 4 16:43:36 dnsmasq[495]: warning: ignoring resolv-file flag because no-resolv is set
Jun 4 16:43:36 dnsmasq[495]: using nameserver 8.8.4.4#53
Jun 4 16:43:36 dnsmasq[495]: using nameserver 8.8.8.8#53
Jun 4 16:43:36 dnsmasq[495]: read /etc/hosts - 5 addresses
Jun 4 16:43:36 dnsmasq[495]: read /etc/pihole/local.list - 2 addresses
Jun 4 16:43:36 dnsmasq[495]: failed to load names from /etc/pihole/black.list: No such file or directory
Jun 4 16:43:40 dnsmasq[495]: read /etc/pihole/gravity.list - 122436 addresses
Jun 4 16:43:55 dnsmasq[495]: exiting on receipt of SIGTERM
Jun 4 16:44:13 dnsmasq[524]: started, version 2.76 cachesize 10000
Jun 4 16:44:13 dnsmasq[524]: compile time options: IPv6 GNU-getopt DBus i18n IDN DHCP DHCPv6 no-Lua TFTP conntrack ipset auth DNSSEC loop-detect inotify
Jun 4 16:44:13 dnsmasq[524]: warning: ignoring resolv-file flag because no-resolv is set
Jun 4 16:44:13 dnsmasq[524]: using nameserver 8.8.4.4#53
Jun 4 16:44:13 dnsmasq[524]: using nameserver 8.8.8.8#53
Jun 4 16:44:13 dnsmasq[524]: read /etc/hosts - 5 addresses
Jun 4 16:44:13 dnsmasq[524]: read /etc/pihole/local.list - 2 addresses
Jun 4 16:44:13 dnsmasq[524]: failed to load names from /etc/pihole/black.list: No such file or directory
Jun 4 16:44:18 dnsmasq[524]: read /etc/pihole/gravity.list - 122436 addresses
[✓] ** FINISHED DEBUGGING! **
* For more information, see: https://pi-hole.net/2016/11/07/crack-our-medical-tricorder-win-a-raspberry-pi-3/
* If available, we'll use openssl to upload the log, otherwise it will fall back to netcat.
* Using openssl for transmission.
* A local copy of the debug log can be found at: /var/log/pihole_debug-sanitized.log
It fails to upload, I verified the "gateway" showing up as a default, even though I configured the gateway (with pihole -r) to 192.168.0.1, it looks like it's still referencing 192.168.1.1.
I set 192.168.0.253 and 192.168.0.1 as the gateway probably about 5 times at this point, looks like some values aren't being reset after reconfiguring.
Did you check the IPv6 box during installation or reconfiguring? If so, then it's no issue because the installer couldn't find a suitable IPv6 address to use (one that wouldn't change). Normally then it also means you don't have an IPv6 internet connection.
