New too this sorry for lack of info of knowledge
pi hole up and running downloaded ubound, when i set my dhcp server on my pi hole i turn it off on my router then my internet freaks out and doesnt work until i turn back on the dhcp server on the router
all i know is i have a raspberry pi 4 my router is NightHawk(R) x4s just try to use pi with unbound to block all ads all i know is its not acting right
debug token:
https://tricorder.pi-hole.net/mrN30HoA/
jfb
May 25, 2023, 3:51pm
2
You have a number of problems with your group assignments for domains, clients and adlist. Every client, domain or adlist should be assigned to at least one group. You have effectively disabled all blocking.
*** [ DIAGNOSING ]: Groups
id enabled name date_added date_modified description
0 0 Default 2023-05-24 18:11:22 2023-05-24 18:11:26
*** [ DIAGNOSING ]: Clients
id group_ids ip date_added date_modified comment
1 DC:A6:32:82:E8:A7 2023-05-24 16:11:07 2023-05-24 18:01:46 HomeDesktop(redacted)
2 DC:EF:09:E5:7D:71 2023-05-24 16:11:47 2023-05-24 16:21:25 HomeRouter
3 F4:03:2A:AE:9D:50 2023-05-24 16:20:35 2023-05-24 18:01:23 HomeFireStick(redacted)
4 A4:8D:3B:FF:23:40 2023-05-24 18:01:05 2023-05-24 18:01:05 HomeDadsTv
5 0C:8B:7D:E6:6B:35 2023-05-24 18:03:16 2023-05-24 18:03:16 HomenameredactedTV
6 FC:49:2D:52:6D:1F 2023-05-24 18:05:11 2023-05-24 18:05:11 HomeFireStick(Dads)
7 00:00:00:00:00:00 2023-05-24 18:06:14 2023-05-24 18:06:14
9 0 7C:F3:1B:CC:2D:8E 2023-05-24 18:26:53 2023-05-24 18:26:53 redacted Phones
10 0 76:9A:FC:FA:4F:78 2023-05-24 18:30:15 2023-05-24 18:30:15 Iphone 13 Max Pro (redacted)
*** [ DIAGNOSING ]: Adlists
id enabled group_ids address date_added date_modified comment
1 1 https://raw.githubusercontent.com/StevenBlack/hosts/master/hosts 2023-04-30 11:03:34 2023-04-30 11:03:34 Migrated from /etc/pihole/adlists.list
2 1 https://raw.githubusercontent.com/PolishFiltersTeam/KADhosts/master/KADhosts.txt 2023-05-01 11:04:16 2023-05-01 11:04:16
3 1 https://raw.githubusercontent.com/FadeMind/hosts.extras/master/add.Spam/hosts 2023-05-01 11:04:16 2023-05-01 11:04:16
4 1 https://v.firebog.net/hosts/static/w3kbl.txt 2023-05-01 11:04:16 2023-05-01 11:04:16
5 1 https://adaway.org/hosts.txt 2023-05-01 11:04:48 2023-05-01 11:04:48
6 1 https://v.firebog.net/hosts/AdguardDNS.txt 2023-05-01 11:04:48 2023-05-01 11:04:48
7 1 https://v.firebog.net/hosts/Admiral.txt 2023-05-01 11:04:48 2023-05-01 11:04:48
8 1 https://raw.githubusercontent.com/anudeepND/blacklist/master/adservers.txt 2023-05-01 11:04:48 2023-05-01 11:04:48
9 1 https://s3.amazonaws.com/lists.disconnect.me/simple_ad.txt 2023-05-01 11:04:48 2023-05-01 11:04:48
10 1 https://v.firebog.net/hosts/Easylist.txt 2023-05-01 11:04:48 2023-05-01 11:04:48
11 1 https://pgl.yoyo.org/adservers/serverlist.php?hostformat=hosts&showintro=0&mimetype=plaintext 2023-05-01 11:04:48 2023-05-01 11:04:48
12 1 https://raw.githubusercontent.com/FadeMind/hosts.extras/master/UncheckyAds/hosts 2023-05-01 11:04:48 2023-05-01 11:04:48
13 1 https://raw.githubusercontent.com/bigdargon/hostsVN/master/hosts 2023-05-01 11:04:48 2023-05-01 11:04:48
14 1 https://v.firebog.net/hosts/Easyprivacy.txt 2023-05-01 11:05:13 2023-05-01 11:05:13
15 1 https://v.firebog.net/hosts/Prigent-Ads.txt 2023-05-01 11:05:13 2023-05-01 11:05:13
16 1 https://raw.githubusercontent.com/FadeMind/hosts.extras/master/add.2o7Net/hosts 2023-05-01 11:05:13 2023-05-01 11:05:13
17 1 https://raw.githubusercontent.com/crazy-max/WindowsSpyBlocker/master/data/hosts/spy.txt 2023-05-01 11:05:13 2023-05-01 11:05:13
18 1 https://hostfiles.frogeye.fr/firstparty-trackers-hosts.txt 2023-05-01 11:05:13 2023-05-01 11:05:13
19 1 https://raw.githubusercontent.com/DandelionSprout/adfilt/master/Alternate%20versions%20Anti-Malware% 2023-05-01 11:05:39 2023-05-01 11:05:39
20List/AntiMalwareHosts.txt
20 1 https://osint.digitalside.it/Threat-Intel/lists/latestdomains.txt 2023-05-01 11:05:39 2023-05-01 11:05:39
21 1 https://s3.amazonaws.com/lists.disconnect.me/simple_malvertising.txt 2023-05-01 11:05:39 2023-05-01 11:05:39
22 1 https://v.firebog.net/hosts/Prigent-Crypto.txt 2023-05-01 11:05:39 2023-05-01 11:05:39
23 1 https://raw.githubusercontent.com/FadeMind/hosts.extras/master/add.Risk/hosts 2023-05-01 11:05:39 2023-05-01 11:05:39
24 1 https://bitbucket.org/ethanr/dns-blacklists/raw/8575c9f96e5b4a1308f2f12394abd86d0927a4a0/bad_lists/M 2023-05-01 11:05:39 2023-05-01 11:05:39
andiant_APT1_Report_Appendix_D.txt
25 1 https://phishing.army/download/phishing_army_blocklist_extended.txt 2023-05-01 11:05:39 2023-05-01 11:05:39
26 1 https://gitlab.com/quidsup/notrack-blocklists/raw/master/notrack-malware.txt 2023-05-01 11:05:39 2023-05-01 11:05:39
27 1 https://v.firebog.net/hosts/RPiList-Malware.txt 2023-05-01 11:05:39 2023-05-01 11:05:39
28 1 https://v.firebog.net/hosts/RPiList-Phishing.txt 2023-05-01 11:05:39 2023-05-01 11:05:39
29 1 https://raw.githubusercontent.com/Spam404/lists/master/main-blacklist.txt 2023-05-01 11:05:39 2023-05-01 11:05:39
30 1 https://raw.githubusercontent.com/AssoEchap/stalkerware-indicators/master/generated/hosts 2023-05-01 11:05:39 2023-05-01 11:05:39
31 1 https://urlhaus.abuse.ch/downloads/hostfile/ 2023-05-01 11:05:39 2023-05-01 11:05:39
32 1 https://zerodot1.gitlab.io/CoinBlockerLists/hosts_browser 2023-05-01 11:06:43 2023-05-01 11:06:43
33 1 https://dbl.oisd.nl/ 2023-05-01 11:15:49 2023-05-01 11:15:49
34 1 https://www.github.developerdan.com/hosts/lists/ads-and-tracking-extended.txt 2023-05-01 11:17:26 2023-05-01 11:17:26
35 1 https://hosts.tweedge.net/malicious.txt 2023-05-24 17:10:22 2023-05-24 17:10:22
Your DHCP server is still your router, and it is distributing its own IP for DNS, not the IP of Pi-hole.
Timeout: 10 seconds
WARN: Could not sendto() in send_dhcp_discover() (/__w/FTL/FTL/src/dhcp-discover.c:233): Network is unreachable
* Received 300 bytes from eth0:192.168.1.1
Offered IP address: 192.168.1.15
Server IP address: N/A
Relay-agent IP address: N/A
BOOTP server: (empty)
BOOTP file: (empty)
DHCP options:
Message type: DHCPOFFER (2)
lease-time: 86400 ( 1d )
netmask: 255.255.255.0
router: 192.168.1.1
dns-server: 192.168.1.1
--- end of options ---
DHCP packets received on interface wlan0: 0
After you made your DHCP changes, did you renew the DHCP lease on all clients?
ok il delete the groups i dont need them really!?!?, I didn't renew the DHCP lease on all clients i did try to set this last night since then i reverted back to dhcp on router to use internet then made the debug token actually not sure if that matters
Have a look at our documentation to get a better understanding of the group feature:
https://docs.pi-hole.net/group_management/example/
Your device hosting Pi-hole is using Pi-hole for DNS resolution. For debugging purposes, it's better so set an external DNS server there
-rw-r--r-- 1 root root 50 May 24 22:48 /etc/resolv.conf
nameserver 192.168.1.15
