Debug token trying to use Unbound custome ipv4 127.0.0.1#5353
[✓] ** FINISHED DEBUGGING! **
* For more information, see: https://pi-hole.net/2016/11/07/crack-our-medical-tricorder-win-a-raspberry-pi-3/
* If available, we'll use openssl to upload the log, otherwise it will fall back to netcat.
Please try again or contact the Pi-hole team for assistance.
A local copy of the debug log can be found at: /var/log/pihole_debug.log
* unbound.service - Unbound DNS server
Loaded: loaded (/lib/systemd/system/unbound.service; enabled; vendor preset:
Active: active (running) since Sat 2019-11-16 21:51:55 AWST; 1 day 9h ago
Docs: man:unbound(8)
Process: 527 ExecStartPre=/usr/lib/unbound/package-helper chroot_setup (code=e
Process: 565 ExecStartPre=/usr/lib/unbound/package-helper root_trust_anchor_up
Main PID: 596 (unbound)
Tasks: 4 (limit: 4915)
Memory: 17.2M
CGroup: /system.slice/unbound.service
+-596 /usr/sbin/unbound -d
Nov 16 21:51:54 raspberrypi systemd[1]: Starting Unbound DNS server...
Nov 16 21:51:54 raspberrypi package-helper[565]: /var/lib/unbound/root.key has c
Nov 16 21:51:54 raspberrypi package-helper[565]: fail: the anchor is NOT ok and
Nov 16 21:51:55 raspberrypi systemd[1]: Started Unbound DNS server.
-- Logs begin at Sat 2019-11-16 21:17:01 AWST, end at Mon 2019-11-18 07:24:41
AWST.
cont
cou
unbound-checkconf: no errors in /etc/unbound/unbound.conf
grep: invalid option -- '/'
Usage: grep [OPTION]... PATTERNS [FILE]...
Try 'grep --help' for more information.
This was taken with the raspberry pi running over wifi and using CloudFlare as the DNS not unbound. I have not made modem use this pi at moment until unit is working correctly. If you need anything further please let me know. I can run the commands again if you like with unbound ticked for DNS?
Unbound is not set up with the root anchor correctly.
What is sudo sysetmctl --full --no-pager unbound.servicesudo systemctl status --full --no-pager showing for the package-helper checks on the root.key file?
pi@raspberrypi:~ $ sudo systemctl status --full --no-pager unbound.service
Active: active (running) since Mon 2019-11-18 18:45:54 AWST; 12h ago
Process: 458 ExecStartPre=/usr/lib/unbound/package-helper chroot_setup (code=exited, status=0/SUCCESS)
Process: 545 ExecStartPre=/usr/lib/unbound/package-helper root_trust_anchor_update (code=exited, status=0/SUCCESS)
Main PID: 583 (unbound)
Memory: 17.5M
└─583 /usr/sbin/unbound -d
Nov 18 18:45:53 raspberrypi systemd[1]: Starting Unbound DNS server...
Nov 18 18:45:54 raspberrypi package-helper[545]: /var/lib/unbound/root.key has content
Nov 18 18:45:54 raspberrypi package-helper[545]: fail: the anchor is NOT ok and could not be fixed
Nov 18 18:45:54 raspberrypi systemd[1]: Started Unbound DNS server.
pi@raspberrypi:~ $
Memory: 17.6M
pi@raspberrypi:~ $
sudo unbound -d -v
[1574119885] unbound[6438:0] notice: Start of unbound 1.9.0.
[1574119885] unbound[6438:0] warning: unbound is already running as pid 583.
^Cpi@raspberrypi:~ $ root.key
-bash: root.key: command not found
pi@raspberrypi:~ $ sudo unbound-anchor -v
success: the anchor is ok
i just checked sudo vi /etc/unbound/unbound.conf.d has nothing in it.
i have put my config in the following sudo vi /etc/unbound/unbound.conf.d/pi-hole.conf
does that help with your question? about whats in config of unbound? i can put that information up if that will help?
