Please ensure that you are running the latest version of the beta code.
Run pihole -up to update to the latest, then verify that the problem still exists before reporting it.
Question about Beta 5.0:
This is not specifically related to v5, just a question on the best way to continue using pihole in the manner I have with v5. I did a chattr +i /etc/dnsmasq.d/02-pihole-dhcp.conf on the stable to maintain some of my settings. I see I can do the same with v5 and maintain my config. I wonder if there's a better way to handle it though. I use pihole as an ad-blocker, but i also use it as a fully functional dnsmasq server. I run multiple subnets (named vlans) with dnsmasq, use dhcp, and dns etc. Currently, in 02-pihole-dhcp.conf i have things like the following
dhcp-range=tag:vlan10,192.168.128.1,192.168.128.254,6h
dhcp-range=tag:vlan20,192.168.100.1,192.168.100.128,1h
dhcp-range=tag:vlan30,10.100.0.1,10.100.0.30,1h
dhcp-option=tag:vlan20,vendor,MSFT,2,1i
dhcp-match=set:bios,60,PXEClient:Arch:00000
dhcp-boot=tag:bios,netboot.xyz.kpxe,,192.168.128.9
dhcp-match=set:efi32,60,PXEClient:Arch:00002
dhcp-boot=tag:efi32,netboot.xyz.efi,,192.168.128.9
srv-host=_sip._tcp.ucm.mydomain.com,dznet-ucm.mydomain.com,5065
srv-host=_sip._tcp.mydomain.com,dznet-pbx.mydomain.com,5060
is there a better way to handle this without making the config files immutable? I see that i can create something like mycustom.conf in /etc/dnsmasq.d and tbh, i havent tested to see if it will override the 02-pihole-dhcp.conf as my wife runs the change management board in the home and almost always denies maintenance windows.
I have my lan.list heavily populated, but i'm using it more like a simple hosts file, i wasn't sure if i could put other dns records in there, but i suppose i could test that.
