Queries for local DNS records exploding
The issue I am facing:
Anyone else noticed the TTL for local DNS records being zero seconds with one of the later updates?
pi@ph5b:~ $ dig @localhost nas.home.dehakkelaar.nl a
; <<>> DiG 9.16.22-Raspbian <<>> @localhost nas.home.dehakkelaar.nl a
; (2 servers found)
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 54957
;nas.home.dehakkelaar.nl.            IN      A
nas.home.dehakkelaar.nl.     0       IN      A       10.0.0.3
;; Query time: 9 msec
;; SERVER: ::1#53(::1)
;; WHEN: Tue Jul 05 17:18:14 CEST 2022
;; MSG SIZE  rcvd: 63
The current release is missing the local-ttl=2 directive that used to exist before.
When adding that directive in again:
pi@ph5b:~ $ sudo nano /etc/dnsmasq.d/99-my-settings.conf
local-ttl=2
pi@ph5b:~ $ pihole-FTL --test
dnsmasq: syntax check OK.
pi@ph5b:~ $ sudo service pihole-FTL reload
pi@ph5b:~ $
I get a non zero TTL returned again:
; (2 servers found)
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 51186
nas.home.dehakkelaar.nl.     2       IN      A       10.0.0.3
;; Query time: 89 msec
;; WHEN: Tue Jul 05 17:33:01 CEST 2022
Client hostnames that are advertised via DHCP seems not effected regardless of that added directive:
pi@ph5b:~ $ dig @localhost avr.home.dehakkelaar.nl a
; <<>> DiG 9.16.22-Raspbian <<>> @localhost avr.home.dehakkelaar.nl a
; (2 servers found)
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 13571
;avr.home.dehakkelaar.nl.            IN      A
avr.home.dehakkelaar.nl.     2       IN      A       10.0.0.9
;; WHEN: Tue Jul 05 17:39:58 CEST 2022
I noticed these DNS queries exploding when logged into my Syno NAS web GUI.
Details about my system:
pi@ph5b:~ $ cat /proc/device-tree/model
Raspberry Pi Model B Rev 2
pi@ph5b:~ $ lsb_release -d
Description:    Raspbian GNU/Linux 11 (bullseye)
pi@ph5b:~ $ pihole -v
  Pi-hole version is v5.10 (Latest: v5.10)
  AdminLTE version is v5.12 (Latest: v5.12)
  FTL version is v5.15 (Latest: v5.15)
Pi-hole DHCP service active.
Created below DNS record via the web GUI:
pi@ph5b:~ $ cat /etc/pihole/custom.list
10.0.0.3 nas.home.dehakkelaar.nl
Added Unbound using the offical guide.
Added my own directive to advertise two Pi-hole DNS servers via DHCP:
pi@ph5b:~ $ sudo grep -v '#\|^$' -R /etc/dnsmasq.*
/etc/dnsmasq.d/10-dhcp-dns.conf:dhcp-option=option:dns-server,10.0.0.2,10.0.0.4
I'm puzzled that didn't hit you earlier, as that should have been the case since Pi-hole FTL v5.10.1, Web v5.7 and Core v5.5 released from September 2021 (emphasis mine):
Ahahaha, I didnt update for a while and recently hastily updated without reading the release notes because I was working on supporting someone else and had to reply quickly with my versions being up to date.
My mistake :wink:
EDIT: Ow and maybe it happened already before but didnt notice :yum:
; (2 servers found)
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 8052
nas.home.dehakkelaar.nl.     60      IN      A       10.0.0.3
;; Query time: 0 msec
;; WHEN: Tue Jul 05 19:35:19 CEST 2022
Some feedback, after about 24 hours I dont observer those queries exploding anymore when accessing my NAS GUI with the TTL set to 60 seconds.
