Pihole dashboard graphs to show info over time.
Queries & Clients graphs on dashboard timeline is off, delayed about 10-15 mins and not real time.
https://tricorder.pi-hole.net/qx5p5kddv3
I was playing with conditional forwarding and was creating loops of DNS queries between my router and pihole. I reverted back to previous settings with conditional forwarding off. While troubleshooting I did clear pihole_FTL DB like you do for benchmarking domains list.
I also use DoH with Cloudflared. I do have unbound installed but I am currently not using it.
I was trying to clear as many caches as possible including OS arp cache as after a few restarts of the pihole I still had PTR queries leftover from the loop between my router and pihole for local addresses with in.addr.arpa hanging around somewhere. These I believe are mostly gone as I don't see them popping up as frequently in my pihole.log crosses fingers.
I tried 'pihole -r' with no luck. I do notice in the debug.log that there are errors under Dashboard & block page. I have tried 'pihole -f' which appears to have fixed the time scale at the bottom of the graphs. But then I don't see anything graphed and no info box when I hover over. I wait a little bit and once data seems to be coming into the graphs the timeline zooms right in and I get access to the hover boxes with the clients listed.
Thanks for the help.
