Informational only…
I was interested in the effect of using regular expressions and the quality of the gravity.list
For this test, I reconfigured pihole to using the default lists only:
StevenBlack https://raw.githubusercontent.com/StevenBlack/hosts/master/hosts
MalwareDom https://mirror1.malwaredomains.com/files/justdomains
Cameleon http://sysctl.org/cameleon/hosts
ZeusTracker https://zeustracker.abuse.ch/blocklist.php?download=domainblocklist
DisconTrack https://s3.amazonaws.com/lists.disconnect.me/simple_tracking.txt
DisconAd https://s3.amazonaws.com/lists.disconnect.me/simple_ad.txt
HostsFile https://hosts-file.net/ad_servers.txt
I'm using pihole + unbound, so it's possible to check the domains in the gravity.list, by directly asking unbound, this to avoid blocking by pihole.
I used the following script, submitting the DNS queries to the IPv4 unbound address, retry, using the IPv6 unbound address. The script ran for approximately 48 hours (there probably is a better way to achieve this - I said before, NOT a Linux expert…)
#!/bin/bash
sudo /usr/sbin/unbound-control verbosity 0
file=/etc/pihole/gravity.list
RED='\033[0;31m'
GREEN='\033[0;32m'
NC='\033[0m' # No Color
success=0
IPv4success=0
IPv6success=0
counter=1
for i in `cat $file`
do
result=$success
(($(dig @127.10.10.2 -p 5552 +noall +answer $i |wc -c)>0)) && IPv4success=$((IPv4success+1))
success=$(($IPv4success + $IPv6success))
if [ $success == $result ]; then
echo -e "${RED}IPv4${NC} - count:$counter, success:$success / $IPv4success / $IPv6success - $i"
else
echo -e "${GREEN}IPv4${NC} - count:$counter, success:$success / $IPv4success / $IPv6success - $i"
fi
(($(dig @fdaa:bbcc:ddee:2::5552 -p 5552 +noall +answer $i |wc -c)>0)) && IPv6success=$(($IPv6success+1))
echo -e "${RED}IPv6${NC} - count:$counter, success:$success / $IPv4success / $IPv6success - $i"
else
echo -e "${GREEN}IPv6${NC} - count:$counter, success:$success / $IPv4success / $IPv6success - $i"
fi
fi
counter=$((counter+1))
# sleep, I want to keep the pi responsive...
sleep 0.6
done
The result:
number of entries in the list: 136702
resolved (IPv4): 108215
resolved (IPv6): 7
resolved (total): 108222 (79.2%)
failed: 28480 (20.8%)
To be fair, I'm using suricata on my pfsense firewall, there where a total of 2058 blocked replies, example:
This implies there might have been a reply, if suricata didn't drop the reply. It's also good news, using pihole in a normal way with these lists, would have protected me, since the reply would simply be 0.0.0.0 or :: (null blocking)
other suricata messages:
ET TROJAN DNS Reply Sinkhole - Anubis
ET TROJAN DNS Reply Sinkhole - Microsoft
ET TROJAN DNS Reply Sinkhole Microsoft NO-IP Domain
ET TROJAN Injected WP Keylogger/Coinminer Domain Detected (cloudflare .solutions in DNS Lookup)
ET TROJAN Kaspersky Sinkhole DNS Reply
ET TROJAN JS.InfectedMikrotik Injects Domain Observed in DNS Lookup
ET TROJAN Possible WannaCry DNS Lookup
ET TROJAN ABUSE.CH Locky C2 Domain (lvanwwbyabcfevyi in DNS Lookup)
ET TROJAN Known Hostile Domain .ntkrnlpa.info Lookup
In conclusion, I think we can agree pihole is only as good as the lists we feed it. I assume the developers choose these lists for a reason, and even those are not really up to date.
