Qnap LXD Container with Pihole not working after update
-operating system Ubuntu Kinetic on LXD Container
-hardware]_ Qnap TS-230
Pihole was running fine until 2 days before that I updated to the latest version. DNS service not running and FTL is down. I made a clean installation of Ubuntu and Debian also and the problem is still exists. I have an old LXC Container with Ubuntu 18 (so I can't update) with older versions of pihole and is running fine. Today I updated to the version that released today and the problem still exists.
https://tricorder.pi-hole.net/LW7XQQGW/
Noone has an idea why latest version of FTL is not running?
[ DIAGNOSING ]: Pi-hole-FTL full status
   × pihole-FTL.service - Pi-hole FTL
     Loaded: loaded (/etc/systemd/system/pihole-FTL.service; enabled; preset: enabled)
    Drop-In: /run/systemd/system/service.d
             └─zzz-lxc-service.conf
     Active: failed (Result: exit-code) since Thu 2023-02-02 12:06:02 UTC; 22min ago
   Duration: 8ms
    Process: 26976 ExecStartPre=/opt/pihole/pihole-FTL-prestart.sh (code=exited, status=0/SUCCESS)
    Process: 26989 ExecStart=/usr/bin/pihole-FTL -f (code=exited, status=218/CAPABILITIES)
    Process: 26990 ExecStopPost=/opt/pihole/pihole-FTL-poststop.sh (code=exited, status=0/SUCCESS)
   Main PID: 26989 (code=exited, status=218/CAPABILITIES)
Feb 02 12:06:02 ubuntu-1 systemd[1]: pihole-FTL.service: Scheduled restart job, restart counter is at 2.
Feb 02 12:06:02 ubuntu-1 systemd[1]: Stopped Pi-hole FTL.
Feb 02 12:06:02 ubuntu-1 systemd[1]: pihole-FTL.service: Start request repeated too quickly.
Feb 02 12:06:02 ubuntu-1 systemd[1]: pihole-FTL.service: Failed with result 'exit-code'.
Feb 02 12:06:02 ubuntu-1 systemd[1]: Failed to start Pi-hole FTL.
Can I install an older version of FTL (before 5.20)?
Same problem.
There are several threads about this issue already. You can run pihole-FTL as root - see here: DNS service not running
Also looking forward to an update or reverting the last version.
