Hello everyone,
A couple of months ago, around the v6 launch, I shared a basic Python client for the new API and an Ansible collection. Now, for mostly academic reasons, I’m experimenting with a Model Context Protocol (MCP) server that sits on top of the pihole6api library using the MCP Python SDK.
I’ve sketched out a minimal framework here:
https://github.com/sbarbett/pihole-mcp-server
If you’d rather not build from source, there’s a Docker image on Docker Hub:
services:
pihole-mcp:
image: sbarbett/pihole-mcp-server:latest
ports:
- "8383:8000"
env_file:
- .env
restart: unless-stopped
(It should run on Linux, macOS, or Windows, although, full disclosure, I haven’t tried Windows yet.)
By default it exposes an SSE endpoint on port 8383, but you can remap that however you like. To hook it up in Claude Desktop or Cursor, install the mcp-remote proxy and add something like this to your config.json:
"mcpServers": {
"pihole": {
"command": "npx",
"args": [
"mcp-remote",
"http://localhost:8383/sse"
If the MCP server lives on another device, just add --allow-http to override the HTTPS requirement:
"mcpServers": {
"pihole": {
"command": "npx",
"args": [
"mcp-remote",
"http://192.168.1.255:8383/sse",
"--allow-http"
Once you’re connected, you can try out the tools. Here’s a quick demo of adding and removing local DNS records:
I’ve only exposed a handful of methods so far, mostly metrics and configuration endpoints. A lot of the work has been conceptual: MCP as a whole is still finding its feet, and “best practice” isn’t as rigid or well-defined as in more mature ecosystems. The TypeScript SDK is further along and enjoys wider adoption than the Python SDK, so I’m experimenting with different patterns and would love some input.
In any case, let me know what you think:
- Do you see a practical use for this? My main use case is quick, natural-language management of local DNS across multiple Pi-holes, i.e. I spin up text LXCs and want to say “create host testbox1.lan” instead of editing IPs by hand on multiple Pi-hole instances.
- What other natural-language DNS workflows would you find valuable? I can certainly see some usefulness in managing block and allow list exceptions, maybe groups.
I’m approaching this cautiously for two reasons:
- Large JSON payloads can rip through tokens fast, and this is especially a concern with metered usage, like OpenAI's API.
- Destructive actions (deleting records) need guardrails, but LLMs sometimes find ways around them, which is... frustrating.
Always appreciate feedback. What’s missing, confusing, or worth expanding? Thanks for taking the time to check it out!
