Pulling blocklist source into range fails on clean install
Hello,
On a fresh install of pihole, it seems to hang on 'Extracting domains from blocklists..." After a period of time, the pi reboots - but pihole is broken. If I run the install script again, but it gives me the option of Update or Reconfigure. Both options fail. I'm able to fix it by changing /etc/resolv.conf to 8.8.8.8 - then I can reconfigure and pihole starts. However I still see some ads on the test page, and the web admin logs are empty. /etc/pihole/gravity.list does not exist - and if i type pihole -g, I get "Pulling blocklist source into range" with a red X.
How do i fix this?
pzkesmzz0b
Replied on https://www.reddit.com/r/pihole/comments/8vemxq/during_install_hangs_at_extracting_domains_from/
