Proxy Error after installation
I should be able to login to the web panel
Proxy error
Debug Token
Image:
You are not using the shipped web server (lighttpd):
[✗] tcp:*:80 is in use by apache2 (https://docs.pi-hole.net/main/prerequisites/#ports)
"If you have another Web server already running, such as Apache ... change the port on which lighttpd listens, which allows you keep both Web servers running."
I guess I have apache installed, how do I change lighttpd's port?
