Proxmox 64Bit Pi-Hole and Home Assistant
Hello,
I have a 4 GB Pi4 and would like to run 64Bit Pi-Hole and Home Assistant on it.
I've already successfully tried installing both in parallel via Docker, but the update limitations didn't convince me. Therefore, I now want to try Proxmox and run the two products in two independent VMs.
What do you think?
Is the performance sufficient, or will it overwhelm my beloved Pi?
I've already found the following simple guide and am looking for a similar PiHole guide to achieve the most streamlined installation possible. Installing Home Assistant on Pimox Raspberry Pi - SmartHomeScene
Do you have any tips or links where I can find similar help?
