So my Huawei B525s-23a decided it doesn’t believe in “persistence.”
You change DNS… it nods politely… and then on the next reboot it wakes up like:
“DNS? Never heard of it.”
Especially with ISP-flavored firmware, the router either hides the DNS fields entirely or pretends to save them and then wipes everything as soon as it restarts.
Since I got tired of my router gaslighting me, I wrote a small tool that logs in, pushes the correct DHCP/DNS config, and re-applies it automatically if the router resets it again.
Repo here:
https://github.com/illegal-instruction-co/huawei-dhcp-dns-tool
What this thing actually does
Logs into the WebUI using the real HiLink auth flow
Sends the DHCP/DNS XML the UI refuses to show
Detects when the router has “amnesia” after reboot
Re-applies everything every few minutes
Runs as a background systemd service on Umbrel/Raspberry Pi/Linux
No rooting, no telnet, no firmware hacks, no dark magic
If the router keeps wiping DNS, the script politely puts it back… forever.
Why I built it
I’m running Pi-hole and wanted the router to point to it.
The router wanted me to suffer.
That’s the whole story.
How it works (short version)
The tool:
Grabs CSRF token + session cookie
Encodes the password with Huawei’s weird login hash format
Calls
/api/user/login -
Sends a complete DHCP/DNS config to
/api/dhcp/settings -
Repeats this every 5 minutes in case the router reboots and “forgets” again
No exploits, no trickery — just using the backend API the UI already uses but conveniently hides.
Tested on
Huawei B525s-23a — fully working
Should work on most HiLink devices with the same API (B315/B310/B535 etc.)
but I haven’t tested them yet.
If you try it on another model, feel free to report back so I can add compatibility notes.
Installation
The repo includes a script that:
Installs the project
Builds it
Creates a systemd service
Starts it automatically on boot
After that, the router can reboot all it wants — the DNS settings won’t stay wrong for long.
Looking for testers
If you have any other Huawei HiLink model lying around and want to make it slightly less annoying, give this a try and share what happens. Worst case, nothing breaks. Best case, your router finally behaves.
