Problems with unbound/unbound servfail
I use Pihole on a Raspi 3B with Raspi OS 64bit (just installed today). My router is a fritzbox 7360. my isp is Deutsche Telekom.
I have been able to use pihole with unbound for several years without any problems.
Last week there was a power outage and I was away for several days. no dns requests could not be answered for 2 days, but on 3 days after the power outage everything was running again without problems.
Then I installed the new 64bit version of raspi os with pihole following the official instructions from pi-hole.net. In the first days there were no problems, but after that unbound stopped answering dns requests. If I select a third party dns provider then everything runs normally again
Today I set up my pi from scratch again, but every time I make an unbound request, there is a serverfail. Right after the installation unbound works for a few requests, but after a few minutes no more.
Currently I am using my pihole with third party dns provider and everything works except unbound.
dig pihole.net @127.0.01 -p 5335
; <<>> DiG 9.16.27-Debian <<>> pihole.net @127.0.01 -p 5335
;; ->>HEADER<<- opcode: QUERY, status: SERVFAIL, id: 3154
;pihole.net.			IN	A
;; Query time: 4 msec
;; WHEN: Sun Apr 10 18:18:26 CEST 2022
;; MSG SIZE  rcvd: 39
dig sigok.verteiltesysteme.net @127.0.01 -p 5335
; <<>> DiG 9.16.27-Debian <<>> sigok.verteiltesysteme.net @127.0.01 -p 5335
;; ->>HEADER<<- opcode: QUERY, status: SERVFAIL, id: 11577
;sigok.verteiltesysteme.net.	IN	A
;; Query time: 0 msec
;; WHEN: Sun Apr 10 18:19:18 CEST 2022
;; MSG SIZE  rcvd: 55
unbound-checkconf:
unbound-checkconf: no errors in /etc/unbound/unbound.conf
sudo service unbound status:
     Active: active (running) since Sun 2022-04-10 17:10:04 CEST; 1h 11min ago
       Docs: man:unbound(8)
    Process: 18941 ExecStartPre=/usr/lib/unbound/package-helper chroot_setup (code=exited, status=0/SUCCESS)
    Process: 18944 ExecStartPre=/usr/lib/unbound/package-helper root_trust_anchor_update (code=exited, status=0/SUCCESS)
   Main PID: 18947 (unbound)
      Tasks: 1 (limit: 839)
        CPU: 350ms
     CGroup: /system.slice/unbound.service
             └─18947 /usr/sbin/unbound -d -p
Apr 10 17:10:04 pi systemd[1]: Starting Unbound DNS server...
Apr 10 17:10:04 pi unbound[18947]: [18947:0] info: start of service (unbound 1.13.1).
Apr 10 17:10:04 pi systemd[1]: Started Unbound DNS server.
sudo nano /etc/unbound/unbound.conf.d/pi-hole.conf:
server:
    # logfile: "/var/log/unbound/unbound.log"
    verbosity: 0
    interface: 127.0.0.1
    port: 5335
    do-ip4: yes
    do-udp: yes
    do-tcp: yes
    do-ip6: yes
    prefer-ip6: no
    # If you use the default dns-root-data package, unbound will find it automatically
    #root-hints: "/var/lib/unbound/root.hints"
    # Trust glue only if it is within the server's authority
    harden-glue: yes
    harden-dnssec-stripped: yes
    use-caps-for-id: no
    # IP fragmentation is unreliable on the Internet today, and can cause
    # transmission failures when large DNS messages are sent via UDP. Even
    # when fragmentation does work, it may not be secure; it is theoretically
    # possible to spoof parts of a fragmented DNS message, without easy
    # detection at the receiving end. Recently, there was an excellent study
    # >>> Defragmenting DNS - Determining the optimal maximum UDP response size for DNS <<<
    # by Axel Koolhaas, and Tjeerd Slokker (https://indico.dns-oarc.net/event/36/contributions/776/)
    # in collaboration with NLnet Labs explored DNS using real world data from the
    # the RIPE Atlas probes and the researchers suggested different values for
    # IPv4 and IPv6 and in different scenarios. They advise that servers should
    # be configured to limit DNS messages sent over UDP to a size that will not
    # trigger fragmentation on typical network links. DNS servers can switch
    # from UDP to TCP when a DNS response is too big to fit in this limited
    # buffer size. This value has also been suggested in DNS Flag Day 2020.
    edns-buffer-size: 1232
    prefetch: yes
    # One thread should be sufficient, can be increased on beefy machines. In reality for most users running on small networks or on a single machine, it should be unnecessary to seek performance enhancement by increasing num-threads ab>
    num-threads: 1
    so-rcvbuf: 1m
    private-address: 10.0.0.0/8
    private-address: fd00::/8
    private-address: fe80::/10
https://tricorder.pi-hole.net/ONwG5Hy3/
This may be your problem:
  1. Edit file /etc/resolvconf.conf and comment out the last line which should read:
unbound_conf=/etc/unbound/unbound.conf.d/resolvconf_resolvers.conf
  1. Delete the unwanted unbound configuration file:
sudo rm /etc/unbound/unbound.conf.d/resolvconf_resolvers.conf
  1. Restart unbound:
sudo service unbound restart
